Question about Philips Audio Players & Recorders
Sa9200/17 connected usb cable from pc to recharge unit but when i disconnected it is hung up.. can't power off, screen shows pc to unit connection. can this be resolved??
Pushed reset button on back, recharged for 4 hrs..
Posted on Jul 13, 2008
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
I've had this HP printer for years with no problem using it most days. just plug it in when i want to print. but for some reason it has just decided that windows does not recognise this USB device. i have...
Disconnect the power cord from back of printer
Disconnect the USB cable from PC
Turn off your PC
Disconnect the power cord from wall outlet
wait for 10 minutes
Reconnect the PC Power cables
Power on the PC
When you see the PC desktop
Re-connect the Power cable to printer
Re-connect the USB cable of Printer to PC
This should resolve your issue
Sep 25, 2010 | Office Equipment & Supplies
When printer connected to pc is showing usb device not recgnised in windows xp
two things to try
  1. try using another usb port ( preferably one on the back of the pc)
  2. switch out usb cable with another
Sep 24, 2010 | Office Equipment & Supplies
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
Usb cdrom on the on the optiplex 760 keeps disconnecting. how can i correct this problem? Talleys.
Could be Hardware or Software problem, try below suggestions 1 at a time to pinpoint the problem.
Hardware:
  1. Restart Computer with USB CDRom not attached. Then attach.
  2. Make sure power connector to USB CDRom is firmly connected.
  3. Change to diffent power outlet for power supply of CDRom
  4. If connected to USB Hub, disconnect and connect directly to the computer.
  5. Try a different USB port on the computer
  6. Use a different USB cable (if using an extender, disconnect) Cable should be 6 foot cable or shorter.
  7. Try a different external CDRom drive to verify it is not a problem within that unit.
Software:
  1. Do windows update. Also Choose CUSTOM update (3rd option is drivers). Update all drivers available.
  2. Download most recent drivers from manufacturers website and install.
Nov 09, 2009 | Computers & Internet
Asrock ALiveNF6G-VSTA Motherboard. Unable to boot to OS
first disconnect ALL cables except power suppliy and frond panel switch. Startup and see if goes further.
dont forget to disconnect the front panel usb cables also !!!
if it goes better, connect he keyboard, reboot and enter bios to see.
etc etc
if it still hungs up at the start with all cables disconnected then a major chip on your motherboard is burnt (maybe the disk controller).
sorry i dont think a solution oher than buying a new motherboard.
Oct 10, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Garmin 760 doesn't work while charing
There is nothing wrong with your gps unit so you can relax and prepare for your trip!
While your unit is connected to the computer via usb cable as in recharging, you cannot operate it as a gps at the same time.
You will find that once the usb cable is disconnected that your unit is working normally.
Enjoy yourself.
Jul 31, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa e270 freezes when USB cable disconnected
Reformat the whole thing with Rockbox. That's the whole point with buying the Sansa, as far as I understand.
Jul 12, 2008 | SanDisk Sansa e270 MP3 Player
Charger will not fit anymore
If you got a USB cable with the unit, you can connect to your PC and recharge the battery that way. Just be sure to have the power switch turned ON. The screen on the player will indicate its connected and you should see the battery indicator in the lower right corner showing a charging condition (bar moving)
Feb 12, 2008 | Audio Players & Recorders
29 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
