Question about Motorola Mobility RAZR V3
Phone turns on but only to hellomoto screen
I've tried everything the only thing that happens is it goes there freezes and i either wait 30 second for it to turn off or take the battery out i don't know what to do can you possibly help me??
  • Anonymous Jul 12, 2008
    same as u described another headache
SEND IT BACK
Posted on Jul 12, 2008
I turn my Apple Ipad on and select a game...30 seconds later it shuts down
Make sure your battery is fully charged or just run with a power cord. Also, the battery could be bad.
Dec 05, 2017 | Apple Cell Phones
Side lx won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 01, 2012 | T-Mobile Cell Phones
It will not turn on
5.Wait 10 seconds.
Step
Thanks
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
Samsung sch-u340 wont start up
5.Wait 10 seconds.
Step
Thanks
Aug 07, 2012 | Samsung SCH-u340 Cellular Phone
My garmin does everything except it justsays locatingthe satelite, but it never goes any further all other things work sound screen etc
First make sure you are in an open area free of trees and other objects, Then turn the unit completely off and wait 30 second then turn it back on, this should now start looking for satelite again and should locate.(This usually only happens around tall buildings or inside a building or other structure such as a house)
Aug 16, 2010 | Garmin GPS
I put a memory card of music on the phone and its just stuck on the screen that says hellomoto
remove the memory card, then remove the battery from the phone. Wait a minute install battery into phone and turn on. If all is good, power phone off before installing memory card. As a safety precaution, do not install or remove memory cards, in any device, with power on.
Sep 11, 2009 | Motorola Mobility SLVR L7 Cellular Phone
When the phone powers on the screen displays "Download"
Okay heres what you do guys!!! Just happened to me today and I fixed it. Mine was at the bottom of a hottub for 2 days XD.
The power in the phone needs to run out
then, plug the phone up
wait about 30 seconds(download screen should be up and it is charging xD.)
Then Take the battery out and unplug the charge from the phone
Stick the battery back in
Wait about 30 more seconds
Hold down the Red Phone untill it turns on.
FIXED! YAYYYYY!
May 19, 2009 | Samsung Propel A767 Cell Phone
Frozen ''hellomoto'' screen on Razor V3c when turning on phone
You have a couple of options:
Take it to a motorola repairer or try to update the firmware on your phone. As you cant get it to go past the Hellomoto screen a hard reset would not possible.
Apr 05, 2009 | Motorola Mobility RAZR V3
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new cellphone..is normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
Phone blinking
there a problem with your phone memory, try adding an external card, if it has one. if you do have an external memory, try to remove it, and power-up your phone. if the problem persist it needs servicing.
Dec 05, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility RAZR V3 Logo
93 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
