Question about PreSonus INSPIRE 1394 External Sound System
Getting software to allow me to use all four inputs at the same time
I can't seem to get the unit to let me use all of the inputs at the same time. help
You can use only 2 front inputs at the same time. But you can use also 2 front and 2 back inputs at the same time
Martin
Posted on Mar 09, 2009
The machine reported problem with Fuser unit and all the four drums at once.
remove all consumables, turn off and leave off for 10 secs, turn on allow the machine to turn over at which point it will ask you to install the consumables, - install 1 at a time then close the doors , allow the machine tostep further and ask you again to install the next unit- this process will change when you get the faulty unit and try to insert, the machine will complain about all the consumables again- now you knowwhich part is faulty- replace -job done
Mar 12, 2014 | HP Office Equipment & Supplies
After the four drive kicks in from a mslippery spot, it doesn't seem to disengage once you get to the bare road and seems to make a sound like it is trying to disengage
Sounds like you have a faulty actuator, when you put the truck in neutral you taking load off of it allowing it to shift it sounds as it has gotten weak over time
Dec 11, 2013 | Ford Explorer Cars & Trucks
Menu menu no longer works first menu only when pushed twice it just exits the first menu again
do a soft reset,with unit off hold down pages and power keys until it starts up and map of usa appears,release keys. Ive done this a few times now and works well I didn't lose any waypoints or data but you will have to reset units of measure etc.
Mar 01, 2012 | Eagle SeaCharter 642C DF iGPS
If I plan to move this TV is there any pre preparation before moving thanks john
Yes there is, and I am glad that you asked. Too many ask for repairs after the move.
First I would unplug the set and allow it to cool down for at least four hours, overnight would be best. I would get some thin foam and wrap it around the front bezel. Then place the largest piece of cardboard that you can find, maybe from an appliance store, and place that over the front screens.
Then shrink wrap the entire unit from top to bottom, and do not allow this unit to lay on its back or sides.
That should help.
If you need any more input.
Please respond to this post.
asnowman
May 26, 2010 | Sony KP-46WT500 46" Rear Projection...
My husband is looking for a user manual for a Terk s-video switch. He got the used item from someone at our church - but they had no documentation for it. Where can I get a user manual?
From my search results, the model number is Terk VS-4. You can view the user manual by clicking here. You need Adobe reader to view it.
More information is given below:
This unit allows you to feed up to 4 stereo audio and video sources to one unit (normally one television which has A/V inputs).
It also allows you to connect a second device such as a portable recorder or amplified loudspeakers to the front AUDIO only output (stereo minijack).
The two outputs are always live.
There are four switches on the top of the unit which allow you to select which of the four inputs you want to use.
Since this is a passive device (no AC or batteries) the input which you select is indicated by a red mark (non-illuminated) which appears when you select the input.
This unit is a perfect solution if you have a receiver or amplifier with no video switching or without enough video switching (or with no S-video capability).
...Placing the unit directly on top of a TV could cause electromagnetic interference. If this occurs simply move the cables and/or the switch box .
S-video signals will only be output when a corresponding S-video signal is connected to the input. For example, if you connect a standard VHS VCR to input 1 using composite video, only composite video (not S-video) will be output from Output #1.
Only output #1 should be used for dubbing or editing, since recording levels will drop if you use both Output #1 and Output #2 simultaneously."
Source
Dec 16, 2009 | Televison & Video
My head unit has 1 set of preamp outputs can i conn. 4 speakers
Yes you can use a y to go to all four. Or you could bridge the four speakers wires onto the two outputs for 1 channel
Mar 31, 2009 | Alpine MRP-F320 Car Audio Amplifier
Power outage in the car or at home
It's a #6 Torx screw. I just took mine apart and the DC input jack fell out, four broken solder joints.
Aug 30, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Remote Control not working
Heh, I got exactly the same problem 3 days ago. Question is, is it the remote or the unit itself?
Dec 30, 2007 | Samsung DVD-HR720 DVD Recorder
Parental control
1. Go to the V-chip selection in the customer menu.
2. If the set has an active PIN code, the menu will display “BLOCK-ING ACTIVE”.
3. Press RECALL on the remote four times within five seconds.
4. The menu should then display “BLOCKING RESET”.
5. Input a new four-digit PIN code and press ENTER.
6. The next menu page will appear which allows you to scroll down to the various lock selections. If you want to remove the PIN code completely, instead of entering a new code, just exit the menu after pressing recall four times.
1. Disconnect AC power for several seconds to reset unit clock.
2. Adjust unit volume to minimum.
3. Press and hold volume down button on unit control panel.
4. While holding the volume down button, press and hold the “Zero” key on the unit remote.
5. The user menu will appear with the V-Chip cursor blinking.
6. Pressing the “Enter” key on the unit remote will open the “New Password” menu.
Have a great day!!
Bill
Dec 09, 2007 | Toshiba MV13L3 13 in. TV/VCR Combo
Sound from digital input(s cut out
You are probably correct. The input switcher IC or the power supply feeding the Optical switcher is most likly got a problem. The cost to diagnoise a problem like this could cost you with a repair, more then you could most likly get a new reciver for. Its a shame of all the great technology that gets thrown aweay in the dumps every day. Good Luck PS please do not forget to rate this thread.
Dec 11, 2006 | Kenwood VR-2090 Receiver
PreSonus INSPIRE 1394 External Sound System Logo
Top PreSonus Computers & Internet Experts
Marcin
Greg Ulan
Tom Chichester
Are you a PreSonus Computer and Internet Expert? Answer questions, earn points and help others
