Jensen JDSC-IR100AC remote extender. Put A flat above tv, and Receiver by digital box and no connection via infrared? I am only 8 ft from tv and digital about 10 feet. Do you have to put the IR extender piece right at the digital receivers signal input?
SOURCE: receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Posted on Dec 13, 2007
SOURCE: user manual for Jensen remote extender
http://157.254.235.130/public/IR100.pdf
Posted on Sep 03, 2008
SOURCE: Jensen - Wireless Infrared Remote Control Extender - JDSC-IR100A
I have also purchased one of these over ebay without a manual. I have gotten it to work as an extender from my basement satellite receiver to the upstairs living room theater TV. I use a channel converter to remote the RF audio and video and this Jensen IR remote to allow control from the living room.
There should be five items in this set. Two dome shaped items, two power supplies and a hockey puck looking IR emitter.
First locate the dome that says transmitter on it. This you want to put at the remote location. This is the dome that you point your remote control at to do your bidding. Make sure its little antenna is extended and the power supply is plugged in. You should be looking at the dome with the antenna tail behind it. The range that you can operate this seems to be somewhat limited. More on this later.
Second, locate the receiver dome. It says receiver on it and has two plug jacks, one for the power supply and one for the IR emitter. Don't worry about that yet, you don't need to plug it in. Raise its antenna, connect its power and set this in front of the devise that is being controlled remotely. You do not need the hockey puck for this to relay your IR beam. Make sure it faces the device being controlled. The antenna tail should face away from the device being controlled.
You should now be able to relay the IR signal. Start by being close to the transmitter. Try a simple on off to verify you have a connection. You can then work at moving away a bit to get an idea on the range capability. I have read several reviews that say this range is very limited, maybe only 5 feet ! I am not sure if this is true in all cases, but be aware of it. Secondly experiment with the receiver placement to get reliable relay to controlled device.
The hockey puck can be used to put the signal in a closed in spot like behind a door in a cabinet etc. In this case, plug it into the receiver and stick it over the IR led on the item being controlled. By the way, I have not gotten this to work on the unit I have. Not sure why. I am also clueless on the visible red LED in the receiver. It seems to glow when I pass my hand around the antenna and does flash when a signal is relayed. It would be nice to know what this is intended to do.
I hope this helps.
If anyone has the manual, I would be interested as well.
Posted on Nov 20, 2008
SOURCE: have att uverse receiver in bedroom hooked to a
Read in other forums that some lcd tv may interfear with infarated signal....I didn't know this when i had my problem had to put my reciver inside closet away from tv for it to work......
Posted on Jul 03, 2009
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
I have a jensen Je 1911 dvdc, it will not stay on but 8 seconds help we have 8 days left
Jensen 19" 12-Volt TV/DVD - Camping World
www.campingworld.com > ... > TVs & Accessories > TVs
Rating: 2 - β€Ž2 votes - β€Ž$269.00 - β€ŽIn stock
Where does one get a replacement remote for the 19 inch /dvd model ??/. 1 answer(s)... Need remote replacement for Jensen JE1911ABC. 1 answer(s).
JENSEN LCD TV Accessories - Jensen RV Direct
www.jensenrvdirect.com > Products > LCD TVs
Items 1 - 12 of 22 - We also offer video control centers, PAL tuners, and digital tuner boxes which will convert your analog TV signal into a digital one.
postheadericon JENSEN JE1914DVDC DVD STAND
dynastre.tk/469748/dvd-jensen-je1914dvdc-stand
Dec 27, 2015 | Jensen Televison & Video
I need to replace the infrared sensor unit for Vizio L37 HDTV.
Good day!!!
Before I answer your question let me clarify something..
  1. What sensor you need to replace is it on the remote IR (infrared) or the receiver on your TV?
  2. Did you try other remote control?
  3. How did you say that you need to replace the IR sensor or receiver on your TV?
To test the remote please use a digital camera..How? place the shot to infrared of your remote then look at the screen of your camera after that press any button on your remote and look if the IR sensor lights up..
Please answer all my clarifications for me to diagnose the exact problem..Because replacing of IR sensor on TV is difficult..
Thank you for using fixya and choosing my service..
Dec 11, 2011 | Televison & Video
I have a Jensen Remote (Universal) and I need the code(s) for a Sansonic Converter box
0144
Here is a site if you need other Jensen remote codes
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/jensen/jr300-400-500-manual.zip&area=other
Oct 06, 2011 | Digi Sansonic FT-300A tal To Analog TV...
I just purchased a Sony flat screen tv and need advice on what wires I need to connect my Denon AVR-3300 to it or to the dish cable box? My remote has these options on the remote to listen in...
Your reciever has three digital optical inputs so, what it comes down to is how many thing do you want to hook up and what input/otput do you have on your TV. Best case scenario would be to hook your cable box directly to your TV Via HDMI out, if you have HD, on your cable box to Sat/cable input on your TV. Next best would be using componenet cables for video and digital optical for audio. Last would be RCA(yellow, white and red, from Cable box to TV input. Then, you would connect your TV to receiver via(best) digital optical, or RCA. You can try to patch the video through the reciever using component or RCA to TV/DBS on receiver then out to TV but. alot of times you will lose the video in the transfer and it uses more cables, thus more margiin for error. You would set your TV menu to cable/sat and your reciever to which ever input you choose.
Jul 03, 2011 | Denon Audio Players & Recorders
Remote on my jensen vm9412 dont work check the battery to see if it is in right. just brought radio.
Try this first to see if the remote is sending out the signals. Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 31, 2010 | Jensen VM9410 Car DVD Player
Cant get remote for sharp 32 in to work new batteries in it not receiving
Is this the original Sharp remote or Universal remote controller? If you do not have a remote checker, you can verify if the remote is putting out any infrared signal by pointing at your digital camera lens, you should see flashing light on your digital camera screen. If it does put out signal, then it can be the IR receiver in the TV itself.
Oct 29, 2009 | Sharp Televison & Video
I have a comcast digital cable box,SHarp Aquos HD TV, Onkyo r430 receiver and a Sony BluRay player hooked up via HDMI to TV. Blue ray input to Receiver is coax. However, I can not get any sound out of hte...
digital input must be enabled, via the onkyo remote or thru the front panel . without the manual or remote your screwed, i have the same problem ,but if you have the remote you just have to play around with the sound settings on this input only sorry i coudnt help more ohmega1080@yahoo.com
Jun 21, 2009 | Tvone TV-207 Television
I hope this helps.
Sep 29, 2008 | Televison & Video
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Computers & Internet Logo
399 people viewed this question
David Payne
David Payne
