Question about LG WM-2277HW Front Load Washer
LE on LG washing machine
Same problem, just happened today..have had the washing machine for 3 years, never happened before...how do we fix it???
  • Anonymous Jul 23, 2008
    I have not had a problem with my washer and we have had it for 3 years. I had a LE signal come up and the washer won't spin, it makes noises and will let water in, but no spinning. I took all the laundry out and tried it again, it started to spin on delicates once, but wouldn't continue.
  • 489 Answers
More than likely, the motor sensor has failed and needs to be replaced.  You will need to purchase the motor sensor from LG.
To replace the motor sensor, remove the 4 screws in the back panel to gain access to the motor.  Using a 17mm socket, remove the center bolt holding the rotor.  Remove the rotor.  Using a 10mm socket, remove the 6 bolts holding the stator assembly.  Holding onto the stator, allow the stator to come down and you will see the sensor located on the bottom of the stator.  Replace it and you should be good to go.
If this is too complicated, call a qualified LG technician.
Posted on Jul 23, 2008
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
LG TurboDrum DD 8 kg WT R801 machine with LE error. Usually I can override the spasmodic message by manually setting the wash, rinse and spin cycles, but not today. The motor speed indicator is not
You have an intermittent problem with the machine's motor. Have the stator and rotor sections of the machine checked out by a qualified electrician.
Jan 01, 2015 | LG Washing Machines
LG WASHER LE CODE
Fix for Error Code "LE" on LG Front Load Washing Machine
I just had an interesting experience with our LG washing machine today. I found some hints for the solution online buried in some user forums, but I thought posting my particular solution here in a less cluttered blog might make it easier to find.
I had just run a load of laundry, emptied the machine, and reloaded. I put the detergent in and started the machine. After sitting for about 2 minutes with no activity, a "LE" error message appeared.
While the online forums indicated this might be a problem with a sensor, I was able to solve the problem by doing the following:
1. Press the Power button
2. Manually rotate the hopper 4 times clockwise and 4 times counter-clockwise.
3. Press the power button and run the machine normally.
Don't know if this will work for everyone, but it worked for me. If I keep getting the error message, I'll have to call LG and find out about this sensor I was reading about.
May 30, 2014 | LG WM-2277HW Front Load Washer
LG TROMM Direct Drive WM0642HW when filled and started LE light comes on and machine stops, why. how do I reste or fix
LE is for a overload error. Do the following:
1) Unplug machine
2) Drain machine
3) Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
4) Plug in, power on, and run regular cycle
Feb 27, 2011 | LG Washing Machines
Le error code
IE means that it is taking too long to fill up.
May 28, 2009 | LG WM-0532HW Front Load Washer
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
LG WM2277HW washer LE error
I was also having the LE error problem. I tried removing the unpumped water , tried re-running the load etc....... then I decided to try something else.... just like we have to restart our computers, I thought about resetting the washer so to speak......not sure if it is fixed, I am going to try running another load, but, I UNPLUGGED THE WASHER, LET IT SIT FOR ABOUT 10 SECONDS, THEN PLUGGED BACK IN.... AND THE WASHER WENT THROUGH A CYCLE AND FINISHED.
Jun 15, 2008 | LG WM-2277HW Front Load Washer
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
LG WM-2277HW Front Load Washer Logo
321 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
