Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Thomas where can i get the drivers for the sata hardrive???
  • 2,427 Answers
It should be on the driver cd that came with your main board,, If you need it to install windows, there is a readme file in the SATA/Raid Folder which contain the instruction for putting it on a floppy disc, basically it involves copying the .sys , inf files to the floppy,, The folder to be copied is named floppy
If you dont have the cd consider using Vista or MCE these have sata drivers built into them
Posted on Jul 14, 2008
I need to know what hardrives are compatible with my computer
You can buy any HDD/SSD as long as it has some sort of SATA connection. The differences between SATA, SATAII, SATAIII are mainly speeds. But all will be recognized by your machine.
Nov 07, 2012 | Computers & Internet
I formatted my hardrive and when i want to install Windows Xp it starts fine but then tells me that my hardrive is not installed,how can i fix this? "Setup did not find any Hard Disks Installed in...
Windows XP needs the SATA textmode drivers for it to recognise the SATA hard drive. This can be downloaded from this link:
You will need the SATA AHCI driver
You must then burn the drivers to a CD or copy to a USB stick. When installing windows XP, you will be prompted "press F6" to load additional drivers, at this point the install will ask you to specify where these drivers can be found, if you direct it to the USB or CD Rom (USB is better to avoid disc swapping), it should find the drivers needed and then recognise your hard drive.
The above is a bit academic though, because this does not appear to support Windows XP according to the downloads options on the link
Jul 21, 2011 | Gateway T-6321 PC Notebook
Hi all, I have problem because now i cant install my recovery CD even alt+f10 wont accept, like i didn't push those buttons. I have try to install some other XP cd and i got error like '' we can't find...
Under BIOS setting, set your hardrive to IDE instead of SATA, or use Win XP CD that contains Sata AHCI driver in order to recognize the hardrive.
May 04, 2010 | Acer Computers & Internet
Hi Can anybody help me to get my computer to reconize my new hardrive. I need to format it first as its not been used before. Do I have to go into bios first? if so how do I set the bios up to reconize my...
In the days of AMD Athlon chips we didn't have SATA, but it sounds like you do, and you have hooked the drive up?
1) Make sure the BIOS has SATA enabled as well as IDE
2) Make sure your device manager has a driver for your motherboards SATA controller
3) Open computer management
4) Choose Disk management
5) Initialise disk
6) Create partition.
7) Format as per normal.
Nov 17, 2009 | Computers & Internet
Can't load xp on hp xw4300. Has sata hdd & ide dvd drive. Xp can't detect hard drive and if press f6 it says there is no floppy drive
replace your cables and try again. if unsuccessful locate your hardrives manufacturer ie: maxtor software MAXBLAST , download the hardrive software utility and ``0 fill`` your hardrive to factory default.
Nov 05, 2009 | Cars & Trucks
Trying to format the hard drive but can not find device drivers or partitions
If you have access to another computer, download Gparted BootDisk
This will boot on any system and allow the format assuming the hard drive is actually working
Oct 12, 2009 | Computers & Internet
Have ixtreme 2613 PB have installed hatachi hardrive pre-format (HDT721050SLA360. ) But it doesnt display on computer went into Bio's and it is recognised there and is also on device manager. what do i...
download servicepack three for the latest sata and raid drivers. until you get the driver for the new raid drive, windows wont see it. you can also put ubuntu as a second op sys from inside windows, and it should work in ubuntu. if it does than its a driver issue. this should update the pb drivers, the device itself doesnt require one to work in xp, so it must be the computer that is the issue.....try updating your sata and raid drivers for the controller that came on the PB
Sep 01, 2009 | Computers & Internet
What is the hardrive used on the Acer Aspire L100?
Your PC has a 160Gb Serial ATA (SATA) drive.
Any SATA drive should work for ya. 160 Gb is a good sized drive, so IF you have room in the case you may want to just ADD a drive to the PC instead of replace the existing one.
According to the specifications for the PC you should have 2 more SATA connectors.
Hope this Helps you.
Nov 26, 2008 | Acer Aspire L100 PC Desktop
be sure sata is enabled on the bios, install sata drive driver, this is for your computer to detect a sata drive. connect the drive using sata cable to your board.
May 15, 2007 | ASUS P4P800 Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
