Question about Fedders D Chassis AED24E7E Air Conditioner
Air conditioner wont turn on
I have a Fedders D chassis AED24E7E and it wont turn on at all. Do they have fuses that could have blown?
Posted on Aug 10, 2009
    President:
  • 3,433 Answers
Power at outlet/cord awitch
Posted on May 28, 2009
Turns on but doesn't put out air
MAke sure you have it leaned back and that water is dripping from it in the back if not do so if water still isnt drippin than screw some holes in the bottom so it can drip if it doesnt work than it might have blown up
Jul 11, 2012 | Fedders Y Chassis AEY12F7E Air Conditioner
My central air conditioner wont blow out cool air and wont blow enough to cool the house what could be the problem?
Check the Filter 1st, that might lead you to find either a frozen coil.If neither of those things
are the problem, check to make sure the blower is operating.
Sep 03, 2011 | Fedders A&B Chassis A1A07W2B Air...
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
CAN I ADD FREON TO MY FEDDERS AC ? it gets cool for a few mins then compressor kicks off ! does it sound like low on freon , ?
Take the front cover off and make sure the copper bulb is not touching the fins. Bend out a distance of 1/2 inch
Jun 15, 2010 | Fedders D Chassis AED24E7E Air Conditioner
Wiring for a
L1 to board to one side of thermostat.
Other side of thermostat to one side of compressor overload.
Other side of overload to (C) terminal on compressor.
Should work now.
May 15, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Fedders A3X06F2G window air conditioner fan does not spin
Fan motor is stuck or defective it might need replacement. Check for broken fan blades or obstruction.
Aug 24, 2008 | Fedders A6Q10F2B Q Chassis Room Air...
Fedders won't turn on
you probably blew the fuse behind the control panel. remove the front cover and then remove the control panel (usually a few screws). There should be a glass fuse attached to the circuit board. If its blown then just replace it and you're good to go.
Aug 17, 2008 | Fedders Q Chassis A6Q10F2A Air Conditioner
Heat Not Working
Pls follow the step
1) Check your connector wire to the termostat (possible may be loose).
2) Set your thermostat up to 29C and set to heat control.
3) Check the connector wire to reversing vale (possible may be loose).
If they not solve the problem your Control Board have a problem,pls go to the nearest service center for repair.
Thanks & best regards
Edgz
Jan 18, 2008 | Fedders D Chassis AED24E7E Air Conditioner
Fedders air conditioner beeps but doesn't turn on.
Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Aug 15, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
Fedders D Chassis AED24E7E Air Conditioner Logo
313 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
