Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Microsoft Internet Explorer for Vista
Everytime I try to download or close the program a dialog box pops up, "Internet Explorer stopped working", When I look the reasons up it's decribed as a "APPCRASH".
  • HP Master
  • 2,794 Answers
It could be the last internet expolorer update didn't install properly. You might want to remove it and reinstall it through windows update.
Posted on Jul 12, 2008
Closed internet explorer at runing
When you reset Internet Explorer to its default settings, all changes that were made to Internet Explorer after it was installed are removed. However, this action does not delete your favorites or feeds. To reset Internet Explorer to its default settings, follow these steps:
To reset Internet Explorer automatically, follow these steps:
  1. Click this button:
    fixitbutton1.jpgReset Internet Explorer settings
    Microsoft Fix it 50195
  2. In the File Download dialog box, click Run, and then follow the steps in the wizard.
  3. In the Reset Internet Explorer Settings dialog box, click Reset.
    Click to select the Delete personal settings check box if you would also like to remove browsing history, search providers, Accelerators, home pages, Tracking Protection, and ActiveX Filtering data.
  4. When Internet Explorer finishes applying default settings, click Close, and then click Close again.
  5. Close Internet Explorer, and then restart it.
Let me reset Internet Explorer myself
To use the Reset Internet Explorer Settings feature from Control Panel, follow these steps:
  1. Close all Internet Explorer and Windows Explorer windows.
  2. Click Start Collapse this imageExpand this image vistastartbutton.jpg , and then click Control Panel.
  3. In Control Panel, open Internet Options.
  4. Click the Advanced tab, and then click Reset.
  5. In the Reset Internet Explorer Settings dialog box, click Reset.
  6. When Internet Explorer finishes restoring the default settings, click Close, and then click OK two times.
  7. Close Internet Explorer, and then reopen it. The changes take effect the next time that you open Internet Explore
Mar 15, 2014 | Microsoft Computers & Internet
Will Not Download
What browser are you using?
May 10, 2013 | Acer Computers & Internet
My internet is half working. will allow me to pull up sites but not access them or able to search the internet.
Hi smb343646205,
Welcome to FixYa! How are you doing?
You did not specify the Operating System you are using, whether Windows XP, Vista, or Windows 7.
Anyways, try to reset the Internet Explorer Settings to resolve the problem.
  1. Exit all programs, including Internet Explorer (if it is running).
  2. If you use Windows XP, click Start, and then click Run. Type the following command in the Open box, and then press ENTER: inetcpl.cpl If you use Windows Vista, click Start. Type the following command in the Start Search box, and then press ENTER: inetcpl.cpl The Internet Options dialog box appears. Click the Advanced tab. Under Reset Internet Explorer settings, click Reset. Then click Reset again. When Internet Explorer finishes resetting the settings, click Close in the Reset Internet Explorer Settings dialog box. Start Internet Explorer again. The Reset Internet Explorer Settings feature restores the following items to their default settings:
    1. Home pages
    2. Search scopes
    3. Browsing history
    4. Form data
    5. Passwords
    6. Appearance settings
    7. Toolbars
    8. ActiveX controls
    Hope that helps. Thank you for using FixYa!
Jul 18, 2011 | Microsoft Internet Explorer 8
I foreget how to reset browser
Follow the below steps to reset Internet explorer 7 or 8
  2. If you use Windows XP, click Start, and then click Run. Type the following command in the Open box, and then press ENTER: inetcpl.cplIf you use Windows Vista, click Start Collapse this imageExpand this image vistastartbutton.jpg. Type the following command in the Start Search box, and then press ENTER: inetcpl.cplThe Internet Options dialog box appears.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer settings, click Reset. Then click Reset again.
  5. When Internet Explorer finishes resetting the settings, click Close in the Reset Internet Explorer Settings dialog box.
  6. Start Internet Explorer again.
Nov 25, 2010 | Microsoft Internet Explorer 7
How do you get rid of a microsoft feeds synchronization error
Windows Internet Explorer 8
  1. Start Internet Explorer.
  2. On the View menu, point to Explorer Bar, and then point to Feeds.
  3. In the navigation pane, right-click a feed, and then click Properties.
  4. In the Feed Properties dialog box, under Update schedule, click Settings.
  5. In the Feed and Web Slice Settings dialog box, under Default schedule, make sure that an appropriate value is set in the list.
  6. Click OK to close the Feed and Web Slice Settings dialog box.
  7. Click OK to close the Feed Properties dialog box.
Windows Internet Explorer 7
  5. In the Feed Settings dialog box, under Default schedule, make sure that an appropriate value is set in the list.
  6. Click OK to close the Feed Settings dialog box.
Dec 25, 2009 | Microsoft Windows XP Professional
Im getting error messages at the bottom of my page:saying page done but with errors using ie 7 vista system
You can try running the fix from the following website on the affected machine to reset the IE 7 to factory defaults.
http://support.microsoft.com/kb/923737
In case the above link doesnot work. Following is the manual method for reseting IE
Thanks for using fixya
Proton
Nov 24, 2009 | Dell Inspiron 530s Desktop Computer...
Each time I try to get onto the internet, I get the message ''Internet Explorer has encountered a problem, and needs to close.'' Has anyone else had this happen, or is it just my computer? This started...
IE8 can sometimes act this way. _Uninstal it through the add/remove programs from the control panel.
Reinstal it only if you want to. I don't use it.
Oct 24, 2009 | Microsoft Internet Explorer 8
Internet Explorer 8 crashing when I login to facebook. Help pls!
Try checking what addons are running in IE, it could be a Software conflict , aslo update flash/java/shockwave
also, try loading the page through a proxy
https://cowclock.com
you can use the firstbar but it disables client side scripting
Glype works pretty well and CGI is java re-rewrighting
good luck!
Sep 04, 2009 | Microsoft Internet Explorer 8
Internet exploer closes after I sign in to Yahoo on windows vista
Yes, you are infected. Go to safernetworking.org and download spybot search and destroy the current version.
Go through the thing carefully. If you need a detailed explanation on how to configure it to clean out the system, because it will need to be configured properly, then it can get out the infection.
If it can't, there is another way, but this is the easy way.
Aug 09, 2009 | Microsoft Windows? Vista Home Basic...
Explorer problem
Hi
I suggest to restore the settings of your internet explorer to defaults. There could be bugs during your windows update.
1. Open internet explorer, go to tool --> Internet Options ---> Advanced tab ---> Reset.
Reset all the settings then restart your computer. In case you cannot open internet explorer because it will just give you a white blank page. try the following steps below.
1.1a Click Start -- type msconfig on start search box (for vista only). Click Run (for xp only). a pop up box window will show up (System utility configuration). Look for the tab Services.
Under services tab, put a check on the box that says "Hide all microsoft services" at the very bottom screen. Click apply then close. Restart the computer.
After restarting the computer follow step 1.
Keep me posted
Regards
Oct 18, 2008 | Microsoft Windows Vista Ultimate Edition
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
109 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
