Question about HP Photosmart 2575 All-In-One InkJet Printer
HP ink cartridge problem
"Remove and check cartridge on right"
have done so, but no change
  • Dan Larson Aug 10, 2008
    I also have the same problem. Installed new cartridge and still does not work.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What happens if you unplug the printer and plug it back it in?
New 78 cartridge, no blue
Posted on Oct 08, 2008
I have the same problem. even with a brand new cartridge.
Posted on Sep 11, 2008
Why will my 5520 printer will not print black
IT MIGHT BE THAT THE BLACK INK RAN OUT OF INK SO ITS NOT PRINTING IN BLACK.However try changing the ink cartridge... If you have already done so then remove the ink cartridge and the clean the copper contacts with a lint free cloth... then shake the ink cartridge and then put it back in. then check if it works... if it does not then remove the power chord from the back of the printer without turning off the printer... then press and hold the power button for 30 sec...
then release the power button and then plug in the power chord...
again try printing in black.. if it does not then follow the steps below..
press the setup icon on the printer >> go to tools >> Clean Printhead ...
after it is done again go to setup >> tools >>Align Printer
after it is done check if black prints or not..
if not then Press BL/TL/BL/BL Buttons, in sequence (BL- Bottom Left, TL: Top Left) >>Touch Support Menu>>
Press Right arrow for Reset Menu and Touch OK >>
Press Right arrow for Semiful Reset and Touch OK >>
Wait for unit to Power Down/Turn Off>>
Press Power button to turn the Printer On.
Check if it works or not... if it does not then service the product
Dec 08, 2012 | HP Photosmart 5520 e-All-in-One -...
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Message says: remove and check right cartridge.
    I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
    Please consider the following:
    If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
    If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
    Don
    Feb 19, 2010 | HP OfficeJet 4215 All-In-One InkJet...
    4110 officejet series all-in-one error message saying i installed incorrect ink cartridge? what do i do? it is the correct one
    Supported HP Inkjet cartridge part numbers The HP Officejet 4100 all-in-one series products use the ink cartridges listed in the table below. HP Inkjet cartridges HP 56 black cartridge (19 ml) HP 57 tri-color cartridge (17 ml) HP 28 tri-color cartridge (8 ml) Replacing the ink cartridgesThe power must be turned ON to the all-in-one or the print carriage will not move to the right.
    1. Locate and open the print cartridge access door on the right side of the all-in-one. The print cartridge carriage will move to the right for access. Figure 1: Opening the HP Officejet 4100 seriesc00121089.jpg
    2. Press down gently on the top of the old ink cartridge to release it from the print carriage. Figure 2: Removing an ink cartridgec00121090.jpg
    3. Remove the new print cartridge from its packaging and remove the protective tape from the cartridge as shown in Figure 3. Do not touch the gold-colored contacts. Figure 3: Removing the cartridge tapec00121091.jpg
    4. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage and press them into position as shown in Figure 4. If the cartridge does not snap easily into position, it is not aligned correctly. Remove the cartridge and reposition it. Do not try to force the cartridge into position. The black ink cartridge (HP #56) goes on the right side and the color cartridge (HP #57 or HP #28) goes on the left side. Close the ink cartridge access door when the ink cartridge has been installed. Figure 4: Installing the ink cartridgesc00121092.jpg
    5. A message will appear on the front panel requesting that the ink cartridges be aligned. Follow the steps below to align the ink cartridges:
      1. Press Enter on the all-in-one front panel to start the ink cartridge alignment process.
      2. After the Alignment page prints, place the page into the ADF upside down and with the printed side down as is shown in Figure 5.
      3. Press Enter. The all-in-one will scan the alignment page and finish aligning the cartridges.
      Figure 5: Aligning the ink cartridgesc00121093.jpg
    Correcting error messages that appear after changing a cartridgeAfter inserting the cartridge, the Check Print Cartridge light flashes or one of the following messages appears on the computer monitor:
    • Check the black (or color) cartridge
    • Replace the black (or color) cartridge
    • The wrong black (or color) cartridge is installed
    These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
    1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
    2. Remove the ink cartridge and inspect it.
    3. Verify that it is the correct part number and if it is, reinsert it.
    4. Close the lid to see if the problem is corrected.
    5. If the message is still displayed after a few seconds, remove the ink cartridge again.
    6. Unplug the power cord from the back of the unit.
    7. Clean the electrical contacts on the ink cartridge with a soft clean cloth slightly dampened (not wet) with clean water. (See Figure 6) Each contact is very small and shaped like a rounded square. Figure 6: Cleaning the cartridge contactsc00121094.jpg
    8. Allow the ink cartridge to dry for a few minutes before reinserting the cartridge(s) and turning on the printer.
    9. If the problem remains, replace the ink cartridge.
    10. If the problem still exists after trying all of the steps above, the unit may need to be serviced. Contact HP for further troubleshooting or to arrange to have the unit serviced.
    Make sure what ur using isn't a refilled cartridge and if it is check the expiration date, if nothing is wrong then you need to get urself a new printer or an upgrade so call up hp at 1800-474-6836 and get help of them,they'll guide you to a new /upgrade printer.
    it's not a nice way of saying it but someone has to give you the bad news
    Feb 01, 2010 | HP Office Equipment & Supplies
    How do you change the ink carterage in an hp officejet 5610v all-in-one?
    Hello !
    To change the ink cartridge(s) in your printer,
    Open the print-carriage access door by pulling it forward.
    The print carriage moves to the far right side of the HP All-in-One.
    Remove the cartridge.
    Take the new cartridge from the package.
    Remove the strip from the cartridge without touching the metal back.
    Insert the cartridge.
    Hope this helps.
    Oct 04, 2009 | HP Officejet 5610 All-In-One InkJet...
    Changed black ink cartridge and now the carriage won't slide-just keeps hitting something that stops it right where the carriage goes to change ink cartridges. mrsgrdng8
    It sound like you may not have gotten the cartridge installed correctly. Remove and re-install the cartridge and see of the problem persists. If it does remove that cartrigde and install the old one and check again. This will determine whether the problem is with the printer or the new cartridge
    Apr 25, 2009 | HP Officejet 5610 All-In-One InkJet...
    I changed out the cartridge and the error comees back saying to check cartridge on right. I've done it several times and can't see thing wrong with what I done.
    I would try a brand new HP black ink cartridge. Those ink cartridges are not made to be refilled according to HP. If you were to call HP and tell them you had a refilled cartridge they would stop the service call right there and tell you to try a genuine HP cartridge.
    Nov 12, 2008 | HP Office Equipment & Supplies
    HP 1610, Remove Cartridge message
    also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
    Sep 30, 2008 | HP PSC 1610v All-in-One Printer
    Alignment
    Remove both the cartridges from the printer and check the expiry dates on both cartridges, if any of the cartridge is expired then change the cartridge and check the result. If the cartridges are not expired then check the ink levels present in the cartridges from the HP Solution Center. If the ink levels are good then clean the copper contacts of the cartridges with a soft cotton cloth and power cycle the printer.
    1. Turn the product off.
    2. Unplug the power cord from the product.
    3. Wait 30 seconds, and then reconnect the power cord to the product.
    4. Turn the product on.
    Now insert the cartridges and align them, after alignment page prints then scan the page.
    If it still gives alignment failed message then remove the cartridges and reset the printer and check for the result.
    Jun 10, 2008 | HP Photosmart 4180 All-in-One Printer
    HP Photosmart 2575 All-In-One InkJet Printer Logo
    249 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
