Question about IBM Lexmark Z715 InkJet Printer
COLOR INK NOT WORKING
I HAVE PLENTY OF COLOR INK BUT IT WON'T PRINT. I'VE TAKEN IT OUT ANDT LOOKED AT IT BUT I CAN'T FIND ANYTHING WRONG.
    Scholar:
  • 133 Answers
Try unplugging the power cord, and replugging it after 1 minute has passed. (Turning the printer on and off with the switch does not work). If nothing changes, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You can also visit the Lexmark website, to see what solutions are being offered for printer problems. They usually have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out. Please take a moment to rate the info I have provided, by using the rating system below. Thanks.
Posted on Jul 13, 2008
How to print when a color is empty in a HP Photosmart 6100
I have a epson printer that does the same thing no matter what i did it would not print anything.The printer companies do that so you will have to buy a new color ink cartridge just to print anything.I think its wrong but who are we to say,when cartridges are $ 50 bucks I think we should have a choice. Sorry I could'nt be more help.
Jul 31, 2012 | HP Photosmart C6100 All-In-One Printer
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
S605 ink printing patchy
A firmware update for your model addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Try to print again to verify that the print quality has improved.
Should the problem continue, it could be that the printhead itself is the problem. Please contact Lexmark Technical Support Center for assistance.
Feb 04, 2012 | Lexmark Interact S605 All-in-One Color...
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Head cleaning not working
Doesnt sound like you Used Genuine Cartirdges?
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 04, 2010 | Epson Stylus Color 740 InkJet Printer
All my photos have a heavy red tint
Be sure you have plenty of all the different inks and that the print head is clean and functioning well. If you are low on one of the inks the colors can be off.
If you have plenty of ink then on of the color print heads may be clogged and preventing that ink from flowing. A few cleaning cycles will hopefully fix this.
Also realize that different inks will render different color reproduction and will especially look different from what you see on your computer, unless you have special software to correct for this.
Dec 19, 2009 | HP Photosmart D7460 Printer
Kodak EasyShare 5300 won,t print Color
Replace Printer Head. It was stoped up. Cleaning didn't do any good.
Jan 18, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printer refuses to print anything
Rerun the CD that came with the printer.
Jan 11, 2008 | Epson CX4200 All-In-One PSC Printer
IBM Lexmark Z715 InkJet Printer Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
