Question about Dryers
Indesit widl126 wont get hot when drying - Dryers
    Champion:
  • 210 Answers
Test thermal fuse and heating element.
Posted on Jul 12, 2008
Indesit widl126
It sounds like the seal is worn out around the hose possibly or it is just loose and needs tightening. Depending on how old your machine is, the hoses get dried and cracked over time as do the seals.
Mar 10, 2014 | Washing Machines
Indesit widl126 does not dry
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
Dec 04, 2012 | Dryers
I have indesit widl126 . door locks, wash light switches on , then nothing . all connections have been checked and are correct . switched it off for 24 hours to see if a reboot would help . no good .
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 19, 2011 | Indesit W 123 Front Load Washer
My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | Washing Machines
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
I have a indesit WIDL126. Half way through through the drying cycle all the lights on the buttons start flashing and it stops spinning. I can still hear the motor working but all I end up with is a machine...
I have had the same problem and this has worked in the past:switch off the machine, then unplug it at the mains. Leave it unplugged for about a minute then plug it back in and try again.
Mar 04, 2008 | Washing Machines
Indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Dryers Logo
414 people viewed this question
Top Dryers Experts
