Plantronics M2500 Consumer Headset Logo
Posted on Jul 12, 2008
Discoverable mode for plantronics
I cant pair plantronic 360 with my computer,its asking me for discoverable mode.
  • Anonymous Mar 17, 2014
    Cant get my plantronics to play music from my samsung 4 eventhough they are paired up what do I do
MazdaCloser
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 20, 2008
MazdaCloser
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
4838
Points
19
1.Turn on both devices (phone and headset)
2. Place the headset in pairing mode by holding the Call Control button (by the mic) down while rotating the Multi-Function Dial upward. Release the buttons when the Status Indicator begins to flash red then green.
3 Use your phon's menu to search for Bluetooth audeo devices and select M2500 by Plantronics when it appears on the display.
How can I make working plantronics 232 with my verizon blackberry 9650
The headset must be put into pairing mode. Once you make your Blackberry phone discoverable, then put the Plantronics 232 headset into pairing mode by pressing the call control button until it flashes red and blue. If it's not flashing red and blue, then it is not in pairing mode. Here is a link for the pairing instructions for the 230 headset (which is the same for the 232):
Plantronics Explorer 232 User's Guide
Good luck from Headsets Direct!
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Is the plantronics 232 headset compatible with the HTc Inspire
The Plantronics Explorer 232 is compatible with the HTC Inspire. Once you make your phone discoverable, then put the headset into pairing mode by pressing the call control button until it flashes red and blue. Here is a link for the pairing instructions:
Plantronics Explorer 230 Pairing Instructions
2helpful
I have an plantronic m100 how to u pair up with ps3
Once you make your ps3 discoverable, then put the Plantronics M100 headset into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the M100 user guide with the pairing instructions.
Plantronics M100 User's Guide
I cant sink with my iphone 4?
Once you make your iPhone discoverable, then put the Plantronics Backbeat 903 into pairing mode. With the headphones powered off, press and hold the Power / Pairing button until the LED Indicator flashes blue and red. Here is the link below for the Backbeat 903 user guide that has the pairing instructions as well.
Plantronics Backbeat 903 User's Guide
I forgot the cod
Once you make your phone discoverable, then put the Plantronics 230 headset into pairing mode by pressing the call control button until it flashes red and blue. The passkey code is " 0000 " (four zeros). Here is a link for the pairing instructions:
I cannot connect my Plantronics Voyager Pro to my iPhone 4.
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Plantronics 330 unable to get the bluetooth in discovery mode
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 headset into pairing mode by holding the call control button until the headset flashes red and blue. Click on the link below for the Explorer 330 user guide with the pairing instructions.
Plantronics Explorer 330 User's Guide
Cant set to my phone
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
20helpful
Pairing Plantronics-E220 Bluetooth w/ my Pantech Matrix C740 Cell
Hold down the call button on the headset and wait for it to flash slowly blue. Make sure your phone is in "discoverable" mode. You should see your phone asking to connect to the plantronics headset. When it asks for a code, enter 0000.
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
