Question about Pentax Optio M20 Digital Camera
Pentzx Optio M20 Digital Camera
The camera will not stay on. When I turn it on the screen says "green mode" and will not stay on l;ong enough to take pix, change settings or anything. I have changed the batteries several times, thinking I got a bad pack, but that doesn't work. Help, I love the camera and want to use it again.
  • 797 Answers
When a problem arises such as this it is a half and half so to speak to find what is happening.
If the camera has a small battery similar to the bios battery in a computer, then remove that battery. Leave it out for at least one day. Some cameras don't have this removable battery, and have internal caps or batteries. In any case remove the main battery or batteries. Let the camera sit for at least 24 hours. That should drain all power. Then after that period, put in a fresh battery or batteries, and see what happens.
I have had problems like this, and ended up using the camera for parts. That may be your choice if all fails. Sell it for parts/repair/AS IS on a site such as Ebay or Yahoo. Then you can get another camera. You may have the joy of finding one like it on a site.
Posted on Jul 19, 2008
My camera will come on and the shut off immediately it is an optio m20 I am not sure it it is the setting but how do i get it to stay on long enough to change the setting?
Yep, it happened to my friends optio m20 and I've just fixed it, but it took about 15 minutes of random button bashing to solve. It is hard to say exactly which combination succeeded (it was all a bit frenzied), but I had my left hand continually switching the camera on and off whilst my right hand was on one or both of the bottom buttons (menu and recycle bin) I then pressed the zoom button and the whole thing kicked into life with a message saying green mode must be switched off. this was achieved by pressing the bottom right recycle button.The camera is now performing normally. I'm not a camera engineer but i'm not one to be beaten,so it can be done. Good luck and don't throw it out of the window if at first you don't succeed.
Oct 17, 2009 | Pentax Optio M20 Digital Camera
My m20 pentax is on green mode & powers off after powered on
Do you want to disable the green mode? Is that what you want to happen?
If so, all you have to do is to press the Green button near the four-way controller.
Aug 25, 2009 | Pentax Optio M20 Digital Camera
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
My pentax optio m20 will not flash.have i turned it off
At the back of your camera, there is a circular button and a flash symbol on it. Pust that button it will circulates through "Auto, Flash-off, Flash-on, Red-eye reduction" modes. As you see those modes displayed on the LCD screen of your camera, chose one of them as you wish
(in this case chose the one except "flash-off" mode ofcourse) :)
Jul 08, 2009 | Pentax Optio M20 Digital Camera
Pentax Optio M20
Found the following on a website about these cameras...
http://www.digitalcamerainfo.com/content/Pentax-Optio-M20-Digital-Camera-Review/Modes.htm
"The second, and previously mentioned automatic mode, is the Green mode that restricts the camera controls to two flash settings, three AF options, zoom, and a self-timer setting. This mode locks out the menu systems, manual focus, mode menus and other options. It’s definitely easy to use, as all one can really do is point and shoot."
This may be a internal software confusion problem. If it is, the following may help.
Make sure your buttons or dials are not on AUTOMATIC, that appears to set the green mode.
I think I would remove the batteries. Next, if the camera has a small battery (similar to the bios battery in computers) remove that as well. Let the camera sit over night. You will need enough time for the capacitors to discharge. Then put the batteries in again, and try.
Jun 30, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Pentax optio m20 .. on-off immdly
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Pentax M20 Green Mode Stuck
i just had the same problem....
here's how i fixed it...
turn it on... then as it's loading up... hold the "menu" button
i think this forces it to stay on...
i changed the green button to be something else... not green mode
then i just turned it off and on again
Aug 20, 2007 | Pentax Optio M20 Digital Camera
Pentax Optio M20 Digital Camera Logo
98 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
