I have a peavey 1500 amp. It is a few years old but still should work. The last time i used it it worked fine! I had it in its padded case and dropped it like maybe two 3 feet! it was a straight down drop and it wasnt a bad fall! Now it wont power up at all.. I took it apart and checked the fuse and one fuse was broke. I replaced the fuse and still no luck! everything inside looks fine nothing broke.. any ideas what to check? Or who fixes things like this in Omaha NE
  • edubs4899 Jul 12, 2008
    what kind of place would i look up in the phone book?
  • 682 Answers
You may be have a broken in printed circuit this kind of trouble needs schematics diagram and previous experience in good service center.
Posted on Jul 12, 2008
  • mohamed eltoni
    mohamed eltoni Jul 13, 2008
    audio and music instruments repair or service center
Xr 1200
Old age has finally caught up with both myself and your vintage Peavey. Things like shorted diodes and transistors sometimes do not physically give themselves away, Also, many times it takes a trained eye to discern the components that have failed in a more discrete manner. It's either repair shop or replacement time which I recommend the latter.
Mar 22, 2014 | Peavey Music
Power problems with my Peavey PV-1500
Suspect that the pot is broken, or start cleaning all the back switches, this pv amps suffer from a terrible switch quality.
Mar 15, 2012 | Peavey Electronics Peavey Pv 1500 Power...
Old peavey amp cutting out
time to resolder everything, got a good 10 power eye loupe?
Mar 09, 2009 | Peavey EQ215FX Home Equalizer
One out of the two microphones is intermittent.
Hi Ken....
I just fixed one of those but not for the same issue.
The manual is on the peavey site (archived)
That will tell you if there's a VOX ckt inside.
If opening the case doesnt scare you, open it ( UNPLUGGED) and reseat the ICs(integrated curcuits) that are socketed
Feb 01, 2009 | Peavey Audio Players & Recorders
PV 2600, couple years old, light usage. Connected to two PV SP3K speakers. One channel started to cutout somewhat but not all the way, Switched a few input cables, swapped L&R. Then whole amp shutdown....
Hi..
I've worked on similar units.
Things I'd check first :
Dust in the unit.
Weak solder connections /crusty debris stuff on the input jacks or output terminals
Any flex cables soldered in tend to be a problem on peavey amps I resolder all those contacts.
Checking the amp w/o a load IS NOT a good suggestion.
What style output connections are you using?
1/4 inch, binding post, or Neutrik style?
Dec 29, 2008 | Peavey PV® 2600 2-Channel Amplifier
No sound - peavey bravo 112
I'm assuming that no sound applies to both the clean and ultra modes. You didn't say which tubes you replaced but I'm guessing the input tube was not replaced. Did you keep the old tubes? When "no sound comes out", do you hear any kind of a low level hum on the speaker output? I think the front end tube is open or the switch logic switch is defective. Hope this helps.
Nov 10, 2006 | Peavey (Solo) Microphone
87 people viewed this question
 Grubhead
Grubhead
