Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Whirlpool twin thin
My washer tub is off balance when it get tot he spin cycle it gets off track and I cant seem to get it back on any solutions.
  • 254 Answers
You need to check the suspension of the washer, it could be pads, suspension springs, or even the shocks.
Posted on Jul 12, 2008
  • carrieclass May 20, 2011
    how do you check?
Whirlpool trouble shooting
All Spin cycles regardless of load or even when unloaded and spinning?
If so suspension is broken.........Technician repair only, even the balance weights in the tub are too heavy for DIY to remove and replace springs
Sep 07, 2014 | Whirlpool WFW9550WW Duet 27" 4.4 cu. ft....
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
My washer seems to be "off balance" for EVERY
could be a couple of things ... first check is washer level... then tub springs 3 spring from tub to tub frame and on from rear to back of frame support if all springs in tack then stabiliser pads on skate plate....
Feb 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool thin twin
YOUR SHOCKS ON THE TUB HAVE RUSTED AN THE TUB HAS FALLEN IN,YOU CAN TAKE THE TUB OUT AND USE WASHERS ON TOP AND BOTTOM OF SHOCKS TO FIX IT,THANKS-MIKE
May 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LSR8233EQ0
Check base mount springs, there are 3 from base to tub and 1 from tub to back bottom for counter balancing. If all are ok then you will have a skid plate problem. Best to call for help.
Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
488 people viewed this question
Dan Webster
Dan Webster
Sal De
