Question about Gateway 7210GX Notebook
Problem with laptop- no power
Dead laptop, wont power up
  • 1 more comment
  • willeona2006 Aug 02, 2008
    My laptop will not come on. I tried pushing the button and it won't come on.
  • rongreene2k Aug 05, 2008
    Gateway 7330GZ PC Notebook
    No power the green LED does light. Should the power button ligh as well?
    Tried removing battery and power and holding button in. The contact to the power seems flattens no "spring" when pushed
  • Randall Stoots May 11, 2010
    have you tried to hold down the power key for about 3 minutes and see if it wont reset ?
Replaced your pc to a new one. I recommend DELL or IBM. Acer is good, but weak board.
Posted on Sep 23, 2008
Same problem dead taptop power on no spring action on start button no lite on
Posted on Sep 19, 2008
Remove the battery and open laptop on AC power.
Posted on Aug 10, 2008
    Problem Solver:
I took it to a repair facility and it needs a new motherboard.
Posted on Jul 15, 2008
  • 304 Answers
Test the battery with a volt meter. if its dead you have a common bad DC jack problem
Why wont dell i15rv-9762blk wont turn on
Obviously there are no error messages, so it isn't a simple failure.
Several reasons:
1. Dead or damaged battery - look for laptop battery error light or replace battery (borrow a working battery to test)
2. Dead or damaged Power Supply- look for power-on light to confirm operation. Replace PS if dead. (Borrow?)
3. System board failure. No lights/errors messages etc. Place warranty claim.
Aug 10, 2014 | Dell Computers & Internet
Tip
Simple fix for dead laptop that wont power up when you depress the ON button
The simplest check you can do on a laptop that wont turn on is to remove the battery and try again with just the power lead.
If the laptop will turn on OK then you have a faulty battery that is causing the failure. This is not a test that will fix all dead laptops but it is a great starting point if this works then all you need do is order a new battery these are about £20-£50 depending upon make and model.
on Dec 14, 2009 | Computers & Internet
LAPTOP WONT POWER UP
Your battery could be dead, if you plug in your charger and it still doesn't power up your motherboard isn't just fried, it's dead.
Feb 24, 2013 | Dell Inspiron 1545 Notebook
My Gateway M-6307 Notebook wont turn on
Ezra, It could be: 1. Dead battery due to faulty Charger. Check the voltage of the charger output. Replace if dead. 2. Dead battery NOT because of charger. You can check it by plugging into the wall socket. Replace if found dead. 3. Faulty power jack on the laptop. Replace it if battery is fine. 4. Faulty power on switch. Needs a replacement. 5. Fault ahead of the switch, then need a professional job.
Nov 08, 2009 | Gateway M6307 Notebook
I have a hp pavilion dv9000 laptop and it wont even turn
If you tried it witht he adapter then sounds like the motherboard is dead.
May 17, 2009 | HP Pavilion dv9000t Notebook
Laptop Dead, Wont power up
its power button doe not work please change it as soon as possible
Apr 14, 2009 | Acer Extensa 5420-5687 Notebook
Laptop wont turn on
Try removing the battery and plug in the power adapter and then power on your laptop. If this doesn't work, put the battery back in and plug in the power adapter and try turning it on. If that doesn't work then take the power cable out and try with only the battery. Try in this order and see if it comes back up, if not, you may have some dead hardware.
Mar 12, 2009 | Gateway M305CRV Notebook
Wont come on!
Starting with the easy stuff: Try plugging in the power cord, but not the battery.
If that works, your battery is either dead, or the circuit for it is shorted out.
Are there any signs of life? When you press the power button, do you hear any fans? do see any lights?
Does the screen flicker? Your RAM may be dead if it does.
Oct 05, 2008 | Acer Aspire 5315 Notebook
Hi
This sounds like a tricky one. If you plug everything in and turn it on at the mains do any lights on the laptop come on? Does it do anything at all when you turn it on?
If you get back to me I can proceed to help you further.
Phil
Jul 12, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Laptop trbl
to answer your question "will laptop work if battery is dead, even when its plugged in to an outlet"...the answer is yes. you can even remove your battery and run it off outlet power. As far as your dead laptop...not enough info to diagnose.
Oct 03, 2007 | Gateway 7210GX Notebook
Gateway 7210GX Notebook Logo
584 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
