Question about Canon Rebel XT / EOS 350D Digital Camera
Err 05 stuck flash
  • NoNamesLeft Sep 02, 2008
    flash stuck--thus many settings get error 05
  • Canon Master
  • 2,794 Answers
I did some research on this and it looks like this is a common problem. If your camera is still covered under warranty, Cannon will take care of it.
If it isn't check for any dirt objects within the area of the flash. You can gently lift up on it from the front of the camera as well.
Posted on Jul 12, 2008
I have an err 05 with my Canon 7D
The err code 05 says the same, Flash could not pop up. The manual says, switch off the camera and switch on again.it could be this does not change anything. Just a little more chance, when you switch off the camera and remove the battery. And while it is out, just charge the battery. When you replace the battery and the error reoccurs best guess you have to visit the Canon service centre.
Make sure there is no mechanical obstruction, that keeps the flash from popping up.
Jan 05, 2014 | Canon EOS 7D Digital Camera
Auto flash does not pop up on Canon7D
This usually means the camera thinks there is something connected to the hot shoe, but there is nothing connected to the hot shoe. Likely one of the micro switches under the rails of the hot shoe is stuck, or you need to tighten the hot shoe. Here is a nice guide to fix this:
Jan 05, 2014 | Canon EOS Digital Rebel XS / 1000D IS...
Err 05 message
Impact damage to flash or spillage (usually something sticky like Coke) around the pivots (the two places at the back on either side that the flash attaches to the top cover). Sometimes a small amount of water will cause the screw on the release side of the flash that it pivots on to rust, causing the flash to freeze. Need to take it apart and clean (I use Windex) and lube (grease, not oil!) the pivots. Scrape the rust off the screw with an Xacto knife and then cover with grease so it won't rust again. Just did one with this symptom today
Apr 05, 2012 | Canon Rebel XT / EOS 350D Digital Camera
When taking pic an "err 05" (the built in flash was obstructed). On this camera eos Digital Rebel xti 400D. How do fix this?
The obstruction is often caused by the interior latch which refuses to move. If the flash cover ever opens, move the latch back and forward a few times which "sort of" re-engages it to its normal position.
Jul 03, 2010 | Cameras
Canon eso err 05 how do I fix it ?
This means a flash problem.
The reasons for it may be several ones. Let me go from the one with higher probability to the lower one.
1. Flash is stuck. It is the most comon reason, and more easiest to confirm. When pressed the shutter (or pressed the flash side button in P mode) you hears a repetetive click noise, and the flash won't pop up. If this happens, the flash is stuck.
Sometimes is solved when at the same time you press the shutter button, with the finger (or nail) you gently pull it up. Once is up, check for dirty, or any residues (such as tape glue, sand or something like that) that stucks the flash.
Some persons apply a thin layer of lubricant on the side hinges. Don't put so much lubricant or oil because will get inside the camera, and cause other problems.
2. If not click sound is heard, the either the flash actuator relay or the DC/DC board (that provides power to the flash board) or the flash board are defective. This can be confirmed only in a camera repair shop.
If you need further support, please let me know.
Best regards,
Jul 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Camera Rebel XTi reads error 05 and the flash will not pop up
Err 05 means: Something obstructed the built-in flash's pop-up operation. Turn off the main switch and turn it on again.
Prepare to press the flash request button with your left hand. With your right hand, position your thumb and finger to gently pry up the flash head, perhaps using fingernails. Push the button and pry. With that help, it should pop up.
Dec 20, 2008 | Cameras
Keep getting err 05 stating that the flash is obstructed
does the flash pop up?
Try this in a dark room with the setting on automatic.
If it does NOT pop up, the problem is that the flash is stuck in some way. Try gently prying it up if you can. if not, take it into a camera repair shop to get it fixed.
Nov 18, 2008 | Canon EOS 40D Digital Camera
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Rebel XT error 05
I had the same err 05 problem on my canon 350d. But there was no need to remove or open anything! If you have the camera in front of you looking at the lens, you can see a tiny black switch hidden under the flash. On the right side where the flash is attached to the body you can find a fine black piece of plastic sticking out of the camera body (smaller than 2mm. This switch can easily get stuck with some dust (or a grain of sand in my case)
Carefully clean it (with an ear stick) so it can go up down again as the flash goes open or is closed. (It somehow serves as a mechanical sensor)
This solved my error 05. Remember that this is just a general Flash error indication and there could be another problem triggering the warning.
Sep 15, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
197 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
