Question about Epson Stylus RX500 All-In-One InkJet Printer
Scan when ink cartridge is empty?
Can you still use the scanner function when there is an empty ink cartridge? It won't let me select Scan on the button panel.
    Genius:
  • 1,447 Answers
Hi-
Chances are you can scan from the computer but if you are going to copy using it as standalone it will not scan- try running epson scan from computer.
Hope this help. Thanks for using Fixya
Posted on Jul 12, 2008
Wont scan without ink cartridge empty
Failing to scan when an ink cartridge is empty is the normal behavior of most ink-jet printers. They are printers first and the manufacturers put in a lock to prevent air bubbles or dried blobs of ink stuck in the print system.
Replace the empty ink cartridge and then scan your document. To avoid the issue in the future, get a stand-alone scanner.
I wish that I had a better solution for you.
Oct 15, 2013 | Dell P703w Printer
Printer won't scan because it's out of ink
Unfortunately, all-in-one printers are printers/copiers. The scan to a computer function is a secondary function and the unit has interlocks to keep it from being damaged when the ink is out. There is a way to print with only one ink cartridge in place but this only allows print jobs from the computer. The copy and scan functions are locked. For details, see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01673672&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3742086#N2374 . See the section on Ink Level Indicator (!) and the bottom notch of the indicator blink fast and the Workaround: Print in ink-backup mode
You need a stand-alone scanner if you routinely want to scan to your computer without a printer ink level OK status report.
I wish that I had better news for you.
May 23, 2012 | HP F4480 All-In-One Printer
Won't scan
Hold the right button press for about 10 or more seconds and the menu will appear and you can scan. (the red button with a triangle in the middle on the right of the printer underneath the mini LCD)
Mar 06, 2012 | Canon PIXMA Office Equipment & Supplies
I am trying to scan a document, however the black ink is empty. It only shows the error message that I should refill my ink. Shouldn't I still be able to scan documents?
Must be using PG830 or PG40 50?
For Canon, if either color or black cartridge is empty or out of ink, "Scanner" doesn't work.
That's why your scanner is not properly working.
It's all connected... That's Canon.
Are you refill your cartridge by yourself?
Try "ROADINK" inkjet refill kit. No drill or sharp needles are needed.
It's not only easy to refill, you can have quality printing.
Check out my youtube video, will find how easy refill can be done.
Apr 20, 2011 | Canon MP490 InkJet Printer
Kodak esp 9 printer is out of black ink, meanwhile all i want it to do is scan a paper and it wont do anything without new ink. The computer says the printer is busy, and the printer just says "error...
This is a common problem encountered by printer users and is in fact not a bug but considered a feature by manufacturers who build this function into printers to encourage consumers to buy their expensive ink cartridges. To fix this problem I would buy a 3rd party ink cartridge for use when your ink cartridge is empty. This way you can use your scanner when out of ink (be careful printing with 3rd party ink cartridges, many have mangled or destroyed their printers by using non OEM ink).
Feb 28, 2011 | Office Equipment & Supplies
Do i need an ink cartridge for the fax machine to work and setup
Some brands of fax machines and all-in-one printer/scanner/fax/copiers need the ink cartridge to be present and have some ink in it to perform functions which don't actually require ink.
My dad bought a Brother all-in-one, and he is unable to scan or send faxes unless he replaces an empty ink cartridge first. If you have a Brother fax machine, I'd suggest returning it and buying a different brand. They waste ink on unnecessary cleaning procedures and force you to buy more for stuff that doesn't need ink.
Mar 03, 2010 | Samsung SF-3200 Fax
Can i still scan photos if my ink is empty
YES, it will scan without the printer cartridges. I picked up a Canon MP160 for free at a yard sale this morning. It didn't come with either ink cartridge. When I powered it up, both the cartridge lights came on but it didn't display any error codes. I installed the Mac OS X scanner driver, and MP Navigator. I then used it to scan a 99-page text document into a PDF file. I have not installed the Mac OS X printer driver for it.
Oct 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
MX700 Will not scan with an empty ink cartidge?!
I just came up with the same problem. But if you keep pressing the right most button (the red one) for 5 seconds the message "replace ink cartridge" disappears and then you can use it as a scanner.
Mar 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Epson RX600 will not scan or nuthin' with empty ink cartridges
I cannot help about the Printing problem, because it seems it needs to have all the catridges with some ink to Print.But i can help you about the scan problem.I was having the same issue as you and gave up trying to print, but when i needed to scan i realized the printer didnt let me touch any of the buttons, repeating the same message "change catridge".If you use the EPSON SCAN application that comes with the printer, it lets you scan directly from the PC. It takes longer, dont know why, but at least it scans.I hope it helps.
Jan 10, 2009 | Epson Stylus Multifunction Printer/...
Scanner
yes! you can scan the image to the computer. the printer may not like it w/o the ink.
leave the empty ink cartridge in the printer.
Nov 07, 2008 | HP PSC 2175 All-In-One InkJet Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
410 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
