Back to:
Tags:
GE Advantium SCA1000H 900 Watts Convection / Microwave Oven
Advantium SCA 1001- Will not stop running.
posted by cohrenich on Jul 12, 2008
Even after a 30 second warm up, the unit will not turn off. We can still heat or cook food. One day we simply put something in the unit, closed the dooe and started to run. Any reset suggestions, etc.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 12, 2008
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2985 votes
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If that doesn't work, then I'd say you have a shorted relay on the control board or relay board.
We repair such control panel assemblies for customers nationwide with our guaranteed $39.95 service.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Rating Locked! (?) cohrenich has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Advantium SCA 1001- Will not stop running.:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
Microwave Ovens
we have an intergrated Bosch microwave oven (approx 26...
GE Advantium SCA1000H 900 Watts Convection...
need to change light bulb in a overhead ge microwave both...
My advantium just stopped working tonight - as though the...
This is not the typical bulb replacement question for the...
I need to replace the door assembly, hopefully not the...
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
