Question about Acer Aspire 5600 Series 5630-6951 Laptop
Laptop Dead, Wont power up
I have a dead Laptopm it wont power up, New power supply and battery and still no luck
  • alexfern2 Jul 12, 2008
    No lights come on, the only other information that might help you is that there is a light on the power adapter. When I plug in in the laptop it starts blinking , if its unplugged from the laptop is it steady green. I have installed a new battery but no luck so far. Thanks for your help
    Alex
    Scholar:
  • 46 Answers
Hi
This sounds like a tricky one. If you plug everything in and turn it on at the mains do any lights on the laptop come on? Does it do anything at all when you turn it on?
If you get back to me I can proceed to help you further.
Phil
Posted on Jul 12, 2008
  • Philip McMahon
    Philip McMahon Jul 14, 2008
    Hi
    I'm really sorry but I'm stumped here. The battery shouldn't be a problem so long as the laptop is plugged in. The light coming on on the power supply shows that it is working so I'm guessing that there is a problem with the laptop itself - you've probably already worked that one out!
    I'm guessing that it's short circuiting, but my knowledge of the physical laptop is limited. The one thing I can advise is that you do not continue trying to get the laptop to work as it is as this may cause further damage.
    A problem like this can't really be solved remotely as there are many things that could be causing the problem. I know this isn't much help but I would suggest taking it to a shop or contacting the manufacturer. You may still at least be able to claim on the warranty!
    Sorry I couldn't be of more assistance.
    Philip
Dell inspiron mini wont start when pressing the start button the optical mouse light up laptop wont start I tried the static charge but nothing happens pls help,
If the computer is under warranty you should take it to Dell. If not you can try removing the battery and try to turn it on. If that does not work then you might have to open it up and remove hard drive and memories to see if that helps turning on. My best advice is take it to a service center.
Oct 04, 2014 | Dell Inspiron Computers & Internet
Tip
Simple fix for dead laptop that wont power up when you depress the ON button
The simplest check you can do on a laptop that wont turn on is to remove the battery and try again with just the power lead.
If the laptop will turn on OK then you have a faulty battery that is causing the failure. This is not a test that will fix all dead laptops but it is a great starting point if this works then all you need do is order a new battery these are about £20-£50 depending upon make and model.
on Dec 14, 2009 | Computers & Internet
Why wont dell i15rv-9762blk wont turn on
Obviously there are no error messages, so it isn't a simple failure.
Several reasons:
1. Dead or damaged battery - look for laptop battery error light or replace battery (borrow a working battery to test)
2. Dead or damaged Power Supply- look for power-on light to confirm operation. Replace PS if dead. (Borrow?)
3. System board failure. No lights/errors messages etc. Place warranty claim.
Aug 10, 2014 | Dell Computers & Internet
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
I have a hp pavilion dv9000 laptop and it wont even turn
If you tried it witht he adapter then sounds like the motherboard is dead.
May 17, 2009 | HP Pavilion dv9000t Notebook
My laptop will not powerup .....
so does the laptop turn on at all with just the battery in. or is the battery got a charge
Apr 15, 2009 | Acer Extensa 5420-5687 Notebook
its power button doe not work please change it as soon as possible
Apr 14, 2009 | Acer Extensa 5420-5687 Notebook
Problem with laptop- no power
Test the battery with a volt meter. if its dead you have a common bad DC jack problem
Jul 12, 2008 | Gateway 7210GX Notebook
Laptop trbl
to answer your question "will laptop work if battery is dead, even when its plugged in to an outlet"...the answer is yes. you can even remove your battery and run it off outlet power. As far as your dead laptop...not enough info to diagnose.
Oct 03, 2007 | Gateway 7210GX Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
