Question about Honeywell Heating & Cooling
How do i uninstall my old honeywell mercury thermostat
  • 828 Answers
There are three parts to a T87F thermostat. Outer ring, thermostat body, and base mount. Remove the snap on ring that goes around the dial. Remove three screws from the thermostat that mount it to its base. Remove the thermostat. Disconnect and record what screws each wire attaches to. Remove the screws holding the base to the wall.
Posted on Jul 12, 2008
I want to hook up a new Honeywell thermostat that has 8 wires in place of an old mercury one that had 5 wires
You just need to used that 5 wires. The rest you leave blank. Your new thermostat has stage 2 heat and cooling also 1 for reversing valve which you don't need.
Jan 06, 2018 | Honeywell Heating & Cooling
Two wire connection for honeywell rthl111b thermostat, heating only
What is your question?
If your asking if you can use a 2 wire connection from an older thermostat (most likely an old mercury switch) on the new Honeywell RTH11b
Yes you can.
You will lose some of the features of the thermostat but if all you want to do is turn the heater on and off it will do it.
Oct 22, 2016 | Heating & Cooling
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Wireing a honeywell thermostat
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Jul 24, 2009 | Heating & Cooling
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Honeywell round mercury thermostat - heat not coming on
If you tip the mercury switch so that it makes contact and the furnace doesn't start, it isn't the t-stat. Check the connections, then start checking the furnace.
In any case, ditch the mercury t-stat (recycle it properly) and get a new programmable one if at all posible. It will pay for itself many times over by turning your heat down in the middle of the night and back up by morning.
Feb 09, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell therostat wiring help
Don't assume the wires at the thermistate are correct.
I had similar and had to go all the way back to the heat/AC controller board. I found the colors weren't attached per spec so was fighting the origional installation at the new thermistat.
Also some digital won't control mutizones proerly
Dec 15, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
277 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
