Question about Kenwood Audio Players & Recorders
Need infrared code for ka2060r - Kenwood Audio Players & Recorders
What is the code list please?
An electronic device with remote control has some infrared signals to control it. An universal remote control contains inside some sets of infrared signals. Every signal set has an identificator or code. So code list is document with signal set identificators. It needs to program your remote control to act to controlled device (TV, DVD, etc.)
Mar 31, 2015 | One For All Televison & Video
I have the bush urc-3541 and have put in the code for a Sony tv but it only works with the remote virtually touching the tv infrared panel! Any thoughts why this might be?
It sounds like either the infrared panel is broken or the sensor which sends the infrared signal from your remote is damaged. Usually, infrared is very reliable unless there is something blocking the "line of sight" or the view between the devices. Below is a link to clone an infrared signal to create a new remote or you could simply purchase a universal remote. Good luck.
Fast Hacks 16 Clone Infrared Signals with Arduino
Jan 06, 2015 | Televison & Video
What type of infrared led do i need??
Any infrared Led should work, just beware of correct polarity. More info is needed to understand exactly what the problem your having is. Infrared controls consist of an led and a Infrared photo transistor. And an encoder/decoder/microprocessor circuit. Either one could be causing your problem.
Oct 03, 2014 | Audio Players & Recorders
Need an infrared code for Hp to use on universal remote
If you had a 'learnable' remote control, you could teach it with the supplied remote for your laptop or just buy a new remote for your laptop.
Mar 09, 2014 | Computers & Internet
Infrared Ear thermometar ET-100B
the L means either the temp u took is to low to read or u need to replace the batteries
Aug 10, 2013 | Prestige Medical Infrared Ear Thermometer
Need code for grundig lenaro 77_11
Check these codes. 063,072,025,048,017. If you wish to get more codes, check this link.
Feb 13, 2013 | ColorApples RM-36E Universal TV InfraRed...
Is there a night vision part to enhance vision for this camera?
Generaly most night vision cameras are of the infrared kind where you need infrared lights of typically infrared LEDs.If you can get more infrared leds towards your objects will be better.Or you can buy infrared lamps with independent power and similar to the ones you place on your front yard.I've tried it and it works.
Oct 27, 2010 | Logitech Security Surveillance Camera...
Need Infrared Remote Code...
I had the same problem and it took an act of Congress to solve it. However, I can tell you that through much more hard work and time than it should have taken I discovered the infrared code for my "One-For-All" remote model URC-4021B00 is--0651. Not sure if it's the same for any other remote control models, but give it a shot.
Oct 29, 2007 | Koss KS4110 DVD Player
Infrared
Trutech is made by Goldstar. Try using their codes,it worked on mine.
Oct 17, 2007 | TruTech PVS31170S1W 17 in. LCD Television
147 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
