Question about Hotpoint Refrigerators
Fridge leaks (smal trickle) at the back from the left hand corner, looking at the back. Drain hole is clear and it isn't water coming from on top of the compressor.
  • LeedsKa Jul 12, 2008
    This fridge is only just over 12 months old but has only just started to do this. Do you think I will see a pin hole leak? Where is the water coming from in the first instance? Inside the freezer compartment or condesation from somewhere?
  • LeedsKa Jul 14, 2008
    There is no obvious cover to remove from this fridge/freezer and I'm concerned about damaging the pipework to the compressor and cooling coils. Some advice would be appreciated. Do you think Sweet Rascal is right. Will I be able to spot a pinhole where this water is coming from?
    Genius:
  • 1,847 Answers
Just go through this video i have posted..
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
If this is helpful, Kindly rate Fixya.
Thanks for using fixya.
Posted on Jul 14, 2008
    Genius:
  • 1,011 Answers
Sir,
Its also possible there is a small leak around one of your inlet water valves for water dispensor & ice maker. That dual valve is located in the back corner of the fridge. You have to remove the bottom panel in back to check it. You might want to put a piece of cardboard under fridge overnight to try & pinpoint the location of leak.
Replace the icemaker signal arm in the ON (down) position. Pour a glass of water through the dispenser, but do not drink it. Open the refrigerator door and check for leaks. It you find a leak, unscrew the filter cup and reinstall the filter. You may also want to check the o-ring inside the cup to make sure it is correctly in place.
  1. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  2. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut the water off when replacing it. Also, this filter should be replaced every six months.
Thanks
Good Luck
Don't forget to rate the solution
Posted on Jul 12, 2008
    Genius:
  • 3,422 Answers
Water can leak from these areas:
The bottom front of the refrigerator or freezer door
The back of the refrigerator
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Underneath the front of the refrigerator
The bottom front of the refrigerator or freezer door Self-defrostingrefrigerators usually dispose of the water generated during the defrostcycle via a tube or channel that directs the water to a pan at thebottom of the refrigerator. From the pan, the water normallyevaporates. (See a more detailed explanation of this in the How ThingsWork section of our website).
If the tube or channel is cloggedor obstructed, the water backs up and leaks into the inside of therefrigerator compartment. Then the water builds up at the bottom,inside of the refrigerator. When the water has built up for a time itmay spill out of the front of the door opening. To fix this problem,clear the drain tube or channel and allow the defrost water to flowdown to the drain pan.
In some refrigerators, the defrostwater is intentionally directed down the back wall of the refrigerator,where it then flows to the bottom of the refrigerator compartment andout to a small drain--usually located beneath one of the drawers at thebottom of the refrigerator. If the drain becomes clogged or blocked,the water may back up. To fix this problem, clear the obstruction.
Anothercause may be the following. The refrigerator may have doorframe heatersto evaporate any condensation on the cabinet frame. If yourrefrigerator is equipped with a switch inside that says “energy saver”or something similar, while running in that mode the door heaters aredisabled. Turn the switch to the opposite setting and wait 24 hours. Ifthe condensation disappears the problem is solved.
The back of the refrigerator Watercoming from the back of the refrigerator usually comes from either theice maker water valve or line (if there is an ice maker), or from thedefrost drain pan.
Here's what to do:
  • Ifthe water is coming from the ice maker water valve, check to make surethe water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Wateraccumulating on the ceiling of the refrigerator is usually caused by aclogged drain in the freezer section beneath the evaporator. Theclogged drain will cause water from the self defrost cycle to leak intothe divider between the freezer and refrigerator. This water may thenfreeze and cause condensation build-up on the refrigerator ceiling. Thesolution to this problem begins with unclogging the drain. It may alsobe necessary to remove the entire freezer/refrigerator divider tothoroughly dry the insulation in the divider. Occasionally theinsulation needs to be replaced to prevent a recurrence of the problem.This can be a big job – you may want to hire a qualified appliancerepair technician.
The inside back wall of the refrigerator Insome refrigerators, the water from the defrost cycle is intentionallydirected down the back wall of the refrigerator, where it then flows tothe bottom of the refrigerator compartment and out to a small drain -usually located beneath one of the drawers at the bottom of therefrigerator. If the drain becomes clogged or blocked, the water mayback up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator Ifthe refrigerator is equipped with a water dispenser on the freezerdoor, check if the water line to the dispenser is leaking. Also, checkthe drip pan to be sure it isn’t out of place, broken or cracked.
    Scholar:
  • 135 Answers
Hello sir
Remove any drawer bins that are at the bottom of the fridge and freezer and check that there is no clogging of the drain hole..IF this fridge has one. I am just thinking of my OLD fridge and what I need to do sometimes. Check the seal on the door...is there a gap that air is getting in...DID you just move it recently. Your best bet however to find out what really is wrong is to call a maintenance person to have a good look at it. sounds like the drain in the bottom of the freezer or the tube is clogged. When most self defrosting freezers defrost, the ice melts, runs through a hole or tube in the bottom of the freezer and into a tray under the freezer which is then evaporated from the heat generated by the compressor. if the water cant get to the tray it will eventually run out of the freezer since the defrost timer continues to cycle.
thank u
    Guru:
  • 1,894 Answers
This is a leak for internal portion
please remove the cover and inspect
  • dewan nafees ahmed Jul 14, 2008
    Underneath the front of the refrigeratorIf
Whirlpool top freezer refrigerator has water in bottom refrigerator
when the machine goes into defrost the heater in the freezer comes on and melts all frost off of the evaporator coil,the water goes down a drain line down to where the compressor and condensor coil is and there the water evaporates,your drain is blocked so the water can't drain down and leaks into the fridge section.when you write looking for answers you have to send the model number off of the machine,if the freezer is on top open the fridge door and look on the left side wall up near the ceiling and there should be a tag with model number,unplug the fridge or shut down the cold control,remove everything from the freezer and remove the back inside wall of the freezer,with a hair dryer melt out all the ice under the evap coil,i use a steamer to clean out the drain,if you don't have one you can try a turkey baster or anything that will push air or water down the drain hole,when you think the drain is clear pour hot water into the hole,if it drains down then it's clear,if not keep hitting it,you can also heat up the back center wall and ceiling in the fridge section to help melt out the ice.there's also a heater probe you can buy that you stick into the drain and it raps around the heater,when the heater comes on the probe heats up and keeps the drain from freezing up,you can also use a ground wire from an electrical piece of house wire or from a cable wire,cut a piece around 6 inches,stick it into the hole and rap the end around the heater,if it's a glass heater connect the wire to the metal in front of the heater,if 6 inches is to long trim it down a little so it fits.good luck,if you need anymore help let me know.
Jun 19, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leak
First check the seal is sealing tight. To do this use a piece of paper and close the door it should have resistance when pulling the paper out. If all is good your drain is clogged up. To clean this remove the back panel at the bottom you will see a hole about a 1/2' in diameter clean this out with warm water and a turkey baster or a piece of wire if necessary. Be careful not to puncture the tube. The drain tube runs all the way to the bottom to a drain pan. After it is clear run a baking soda water mix 50-50 down the drain to prevent future clogs. Here is a link to accesssing the drain.
http://appliancehelponline.com/refertopevapfan.html
Jun 03, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water leaking from the bottom of frig
Your  deforst drain is clogged.  Every 12 hours or so your fridge does a deforst cycle.  It melts all of the ice built up on the evap coils.  There is a drain at the back of the fridge that goes to a pan by the compressor where the heat from the compressor and the condensor coils evaporates it.  Take the back panel off of the freezer compartment and plunge out that hole.  You will most likely have a build up of ice over the top of the drain.
May 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
May 23, 2010 | Whirlpool Refrigerators
Intermittant water leak front left hand side and ice build up on inside base of freezer compartment, but no evidence of water leaking out from door it seems to come from underneath the appliance.
Sounds like the drain hose from fridge unit to evaporator pan built on top of compressor is plugged. The drain holes are small and clog easily. I like to make the holes bigger. A pipe cleaner helps to clean the inside of the drain hose.
Make sure water is dripping onto evap tray.
Nov 25, 2009 | Refrigerators
Refrigerator leaks water
most likely you have a plugged drain int he freezer compartment. if yo will look under and behind the lower basket in your freezer you will most likely see a bunch of ice build up. clear this ice out then you will see a drain hole in the center section behind the metal cover in the rear try to get some hot water into this hole to clear ice and to clear the drain then u shoul be good to go. thanks for using Fix Ya Peyton
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Maytag refrigerator leaks water from the freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 23, 2008 | Refrigerators
Whirlpool Top Mount Refridgerator is Leaking
the problem lies behind the freezer back wall panel, remove the panel, the ground (green) wire on the top left corner and the icemaker
all the ice build up under the evaperator will have to be removed, a good hair drier works well, direct the air at the center hole in the bottom of the metal panel all the ice out of the center hole will need to be melted out to be a success it will take a little time. you can pour some water down the hole and if you hear it going into the bottom drain pan then the tube is clear of ice.
Apr 10, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge Leaking water from front right hand corner
yes, get a pipe cleaner and put in to the hole to try and clear if not from the back you will find the pipe which will be clipped to a plastic tray on the compressor. unclip and blow up the pipe this will always clear the blockage.
Oct 19, 2006 | AEG SK78800I Compact Refrigerator
Refrigerators Logo
177 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
