Question about GE Washing Machines
Washer won't stop filling. don't think it is faulty inlet valves. i can't locate any air dome/pressure switch assembly. ge washer model # wwa 8300 balwh
  • 1 more comment
  • Anonymous Jan 05, 2009
    What is the problem when washer continues to fill and overflows
  • Richard Raynor May 11, 2010
    Do you mean it floods the room, or the water seems to go out as quick as it is going in?
    If the latter applies, check that the drain hose hasn't dropped off it's perch on the back of the machine - if it has fallen down the water could be just syphoning out as fast as it is going in.
    If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
    If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
  • Anonymous Mar 15, 2014
    clothes washer- LG wm2455hg
    valve assembly inlet is leaking
    Sergeant:
  • 225 Answers
"Found that a rat had chewed through a hose" - ah, sorry - that wasn't in my faultfinding chart :-)
Posted on Jul 16, 2008
It was actually filling up and flooding the room. Found that a rat had chewed through a hose and repaired the hose inside the washer and it now works fine. Thanks
Posted on Jul 13, 2008
Water continual running piease help
The Water Inlet Valve on your washing machine is used to fill the tub with cold, warm or hot water for the wash and rinse cycles. The valve is operated by electric solenoids that are controlled by the timer or electronic control board and the water level control/water level selector switch or pressure switch. If your washer continues to fill during a cycle, the water inlet valve could be at fault. To verify that the valve is at fault, unplug the washer when the symptom occurs. If the washer continues to fill, then the water inlet valve is defective. If the washer stops filling, then the problem is related to the electrical circuit that controls the valve. The water level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak or is plugged, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill.
To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level pressure switch may be defective. Inspect the switch for signs of a mechanical defect or debris plugging the hole in the inlet nipple. To test the switch contacts for continuity with a multi-meter, you will need to apply the proper amount of air pressure to the air dome tube and then look for the switch to go open circuit at that level. The easiest way to do this is to start the washer and allow it to fill to the normal level and then remove the power cord. Locate the pressure switch and remove the wires from the correct terminals and then perform the continuity test. There should be infinite resistance or an "open circuit" when the water level is correct. If not, then the switch is defectiv
Jan 11, 2017 | Cars & Trucks
My GE Adora washer constantly fills regardless of the cycle even in spin. I replaced the inlet water valve and float switch.
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
lastly if after checking these then u may have a bad mother board
By the way my advice is free cuz God is good!
Jan 25, 2016 | GE Adora Front Load Washing Machine Washer...
Water level
Probable causes:
Faulty water inlet valve - unplug washer, if water continues to fill
replace the valve.
Water level switch, hose or dome faulty - service the assembly.
Timer faulty - unplug washer, if water stops filling test timer.
Regards,
Dennis
Aug 22, 2014 | Simpson Esprit 750 Top Load 7.5kg
Water keep filling til machine overflow and need to turn of water inlet valve
if you have to shut off the water supply valve of the residence (water keeps flowing after turning off the washing machine or unplugging the washer), the failed component is definitely a stuck open water inlet valve (fill valve) of the appliance. If the water stopped by pushing the timer or unplugging the machine, another internal electrical control related problem exists, such as a faulty timer assembly or controller board, or a pressure system failure (water level detection/monitoring system) - failed pressure switch (rare), clogged air hose or tub air dome (common in GE top-load washers), disconnected air hose (common in frigidaire top load washers & GE/Frigidaire/Kenmore stacked washer/dryer combo units).
While a simple repair can be done by yourself for a failed inlet valve, usually for $25-$50 in parts/shipping (go to searspartsdirect.com or appliancepartspros.com to look up a replacement fill-valve using your washing machine model number), the water damage potentially caused by the flooding is more important to address.
I recommend contacting your insurance company if there's a bunch of water that flooded your home - the water can cause delayed warping of flooring or cause mold to grow in/beneath your carpets and walls if the water was not immediately noticed and cleaned up (within first few minutes of flooding) - they send out water remediation specialists to dry (if possible), or to repair the damage to your home.
Dec 26, 2011 | Whirlpool LSQ8243H
No fault code washer will not fill
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool WTW6400SW Cabrio Washer
My washer wont fill with water what seems to be the problem
Hi
Daniel
Aug 10, 2011 | Samsung WF210AN Washer
LG WM1814CW washer - doesn't fill with water. Hear a hum when it should be filling with water, but no water and no error codes. I am guessing Valves (F160 and F170). Any thoughts?
Hi
Daniel
Aug 08, 2011 | LG WM1814CW Front Load Washer
Water not entering washer
Hi
Daniel
Aug 03, 2011 | Maytag Bravos MTW6600T Top Load Washer
When I start the washer it continues to fill up and wont stop
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which one is... while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..The inlet valve is normally located in the back of the machine where the hoses hook up. The pressure switch can normally be found inside the control panel with a small rubber tube attached to it. You should replace the faulty part. If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 31, 2009 | Kenmore 24032\24036 Top Load Washer
Water will not shut off to begin cycle
Does the washer leak water into the tub even when it is not on. If so, your fill valve is leaking or sticking.
I would also check the following components for problems:
-Air pressure switch. This is usually located inside the control area and likely is attached to the water level control. Try attaching a small piece of tubing to the pressure switch and gently blow into it. If it turns off, the problem likely lies elsewhere.
-Air tube. This clear tube can get crimped or worn from the vibration of the washer's normal operation. Any holes, cracks or crimps will prevent the air pressure created by the water in the tub from getting to the pressure switch.
-Soap residue in the air dome. The airdome is the piece attached to the side of the washtub that allows water in the tub to exert air pressure into the tube and the pressure switch. Soap residue can create an obstruction that prevents the pressure from being transmitted up the tube. Try cleaning with vinegar or ammonia. (Remember: Clean the tub and tubing thoroughly with water after cleaning. Ammonia and Vinegar are both corrosive to electrical parts.)
Hope this helps!
May 28, 2009 | Kenmore 23822 Top Load Washer
Washing Machines Logo
222 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
