Question about Acer Computers & Internet
Laptop wont power up
Have a problem with my laptop, Its a Acer Aspire 5670, It wont power up, New battery installed , power harness to the motherboard replaced.
Checked Power Adapter with multimeter , output is 19.55 , Any idea? Suggestions?
    President:
  • 778 Answers
Sounds like the next logical culprit to check would be the surface mount DC jack on the MoBo edge. They are a common fault on laptops/notebooks. You are working in the right direction in my opinion, so cracking open the Puter is next. If you have excellent soldering skills you could flow solder to correct any possible cold/bad solder points and/or use a multimeter to Ohm out points.
Posted on Jul 15, 2008
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
I have an Acer Aspire 5670 (5672WLMi) with a boot problem, the laptop boots, and the battery led blinks and the computer shuts down. I remove the battery and the laptop boots up. The battery is new and...
Hi
Thank you for your query, this is not a too uncommon in acers it would seem you may have a cold solder joint on the motherboard causing a short and ultimatley shutting the laptop down
You will need to book the laptop into a reputable PC shop for repair
I hope this has been useful
Mar 15, 2010 | Acer Aspire 5670 Notebook
Broken vertical lines acer aspire 5670 laptop and
This is usually the actual screen driving transistors packing up, real common. replace the screen, if cheap enough, often though they are more than a new machine.
Feb 23, 2010 | Acer Aspire 5670 Notebook
I have an Acer 5670 Laptop, I replaced the HDD with a new SATA drive and when I powered up the laptop, the Video card fan starts, the CD drive cycles once, the drive light flashes 3 times, then it stops....
Sounds like it. Try taking out the hard drive, disconnect all usb devices and anything attached, and try to run POST again...Being a laptop, there is not a whole lot else you can do if it won't POST. YOu can try swapping in some different RAM that is known to be good also.
Jan 13, 2010 | Acer Aspire 5670 Notebook
Acer aspire 4930 wont turn on
If the power LED on the Notebook is blinking but not turning ON then the issue is related to the power supply unit and service is required.
Nov 03, 2009 | Acer Aspire 4930-6862 Laptop
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
http://cgi.ebay.com/NEW-ACER-ASPIRE-5670-15-4-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ320249932106QQihZ011QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Jun 13, 2008 | Acer Aspire 5670 Notebook
Acer Aspire 5670 laptop base too hot.
this is normal but be carefull it will damage your graphic unit
May 02, 2008 | Acer Aspire 5670 Notebook
Sound problems with my acer aspire 5670
I think ur laptop audio drivers not suppoted speakers.Better to take drivers from nearest showroom or goto www.acer.com and download the drivers.Install it.After installation ,please restart the laptop and check it.
Thanks
Feb 28, 2008 | Acer Aspire 5670 Notebook
Computers & Internet Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
