Question about Fagor Cooktops
' Fagor 2h-134 I ' cooker manual needed
I have just moved into a new home and it has a Fagor 2h-134 i cooker installed and am having trouble working it. Can anyone point me to an Instruction Manual?
  • 59 Answers
Hello
Are you looking for the pressure cooker manual?
Posted on Jul 24, 2008
I cannot unlock my fagor induction hob by pressing the plus and minus signs, what should I do?
check the keylock is not activated by holding down the key symbol for a period of 5 secs.
Nov 08, 2016 | Fagor Cooktops
I have broken the glass on my induction cooker
ENr is on rating plate on bottom of hob. The Ceramic top is easy to replace, it is held on by 3 pozi screws on each side (12 altogether) and just sits on the main electrical parts, obviously the unit should be isolated from main before you remove the top. Part can be ordered using the link
http://www.bosch-home.co.uk/store/spareparts/search
Mar 16, 2013 | Bosch Cooktops
USER MANUAL FOR SAMSUNG CERAMIC HOB C61R2AEE
Samsung has the manual you want is the 1.75 MB PDF at the bottom of the list here: http://www.samsung.com/uk/support/model/C61R2AEE/XEU-downloads . If this second link doesn't work, follow the directions below to reach this page.
Samsung has the User's Guide for the oven on the Support tab, see http://www.samsung.com/uk/consumer/home-appliances/cooker-hobs/ceramic/C61R2AEE/XEU . The support tab is on the right. The manual for the cooking hob can be accessed from the Need More Downloads link below the Download button.
I hope this helps.
Jul 06, 2012 | Cooktops
Hi I have just moved property and I now have a tricity bendix oven that I can't get to work I have used the grill but can't use the oven
Its most probably the clock that needs resetting,by pressing the 2 rhs buttons depending on the model.Try this and hopefully the oven will work again as long as the cooker has been connected correctly.
Hope this has helped.
Jun 25, 2010 | Tricity Bendix Cooktops
Electrolux EOB976: cooker hose or copper pipe?
The regulations state that the proximity of the hob to the cooker would dictate the use of a copper pipe to supply the hob.
Hope this helps.
May 26, 2010 | Cooktops
We have new house and have cold air coming from Jenn-air vent. What can be done to stop this? We had a Jenn-air in our previous home and did not have this trouble
Most stove vents have a diverter plate which prevents air from coming in. When the fan is turned on, this diverter is opened by the air flow and allows the air to flow through. It sounds like this plate is either stuck or was not installed when the ventilation duct was installed.
Oct 16, 2009 | Jenn-Air JED8430 Electric Cooktop
No Longer Available
if you are installing a secondhand gas cooker then you need the manufacturers instructions you need to be a gas engineer and if the parts are no longer available you should get a new unit
Aug 10, 2009 | Cooktops
Fagor cook top connection
Guy from Fagor said brown & blue go to black & red. White and ground together go to green & yellow. Hope he's right.
Apr 04, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Fagor hob touch control
Our hob has the same problem. I would really like to know the reason for this! Try using a rubber eraser instead of your finger - this works every time with our hob. Covering Up and Down arrows with the rubber, zeros it instantly just like using both fingers. Hope this helps.
Jan 28, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Cooktops Logo
1,066 people viewed this question
Top Fagor Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Fagor Cooktop Expert? Answer questions, earn points and help others
