Question about Microwave Ovens
Durabrand xb2316 door will not close causing microwave not to work latch inside has broken can i get part fo it
  • Anonymous Oct 27, 2008
    door will not latch shut and microwave does not work
  • Anonymous Mar 29, 2014
    I need a user manual for the durabrand xb2316. Can you tell me where I may be able to get one?
I am not sure if ur aware but this product has been recalled from asda as it has a fault, overheating and danger of explosion! i have only been investigating recently as i brought one and had a massive house fire due to this product so my home is unlivable and it also nearly killed my dog as i was out of the house at the time. so never mind the door, take the product back they will give u a full refund even without the reciept or packaging.
Posted on Jul 06, 2009
  • Microwave Ovens Master
  • 9,098 Answers
You should contact Durabrand at the number in your owner's manual.
If for some reason you don't have your owner's manual, I would suggest calling the dealer where you bought it to see if they have a number for Durabrand.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
  • Resmi Aug 08, 2013
    I got this particular brand as a gift, and I don't know the dealer details in Dubai,UAE.Can I have the details please... and whether the offer still exist or can I exchange with some thing else?
Microwave door alignment
test all this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 27, 2013 | Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
DOOR LATCH PROBLEM...HOLDING IT CLOSED AND TURNING IT ON WORKS AND HEATS. IS IT A DIY FIX PROBLEM? THANKS FOR THE HELP, DEBBIE
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2gPqmd5pf
Sep 30, 2013 | Frigidaire FGMV174K Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Durabrand xb2316 diagram
send me its connection diagram
hafizfarhanmajeed@gmail.com
Apr 05, 2013 | Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
NEFF H5430NOGB Integrated oven - door won't close, the ;hooks on the door itself seem to have gone loose so they ill not clikc inot place when trying ot close, door just flops open.Amy ideas???
I had this problem. The spring inside the door which pushes the the latches down had broken (plastic peg had broken off).
I managed to fix it by attaching the broken end of the spring to the door frame using a small nylon cable tie using the small hole in the plastic fingers which was already there. Note you need to remove the inside door surround.
See the following link to remove the plastic cover on the door
http://www.fixya.com/support/t1267577-replace_front_glass_door_neff_microwave
I had an interim solution which was to tie some thin string to the latch and feed it under the door and pull on the string when closing the door (when it should be latching.
It was
Dec 06, 2010 | Neff H5430 Convection Microwave Oven
Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Nov 15, 2006 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
331 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
