Question about Miele 24 in. G665 Built-in Dishwasher
Inlet/ drain light keeps flashing
Hi there - the inlet/drain light keeps flasing - i have cleaned all the pipes leading away from the washer and cleaned the filters etc at the bottom of the washer - it will drain any water i put into the machine so any ideas what else i can do before i call in a specialist????
angela
  • 26 Answers
You have a leak and the bottom pan is full of water. You can remove the cover at the bottom front of the dishwasher and see if the bottom pan is filled with water.
Posted on Oct 08, 2008
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
Error F 2 all ligths flasing
Check the inlet and the outlet, check the filters on both the ends as if this is clogged there is delay in filling or draining. Also check the flow of inlet to be good, if not remove and clean the inlet filter and the drain filter.
check this link for tips: cleaning vent
Jan 18, 2013 | Maytag Bravos MTW6600T Top Load Washer
Inlet/drain light flashes on miele dishwasher and it wont start - I can hear the pump but no water - I have checked and cleaned all pipes etc
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Jan 16, 2010 | Miele 24 in. G638 Plus Free-standing...
Whirlpool ADP4542 Flashes 7 times
If that's the clean lite flashing that is a fault code. That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold.
Jan 04, 2009 | Dishwashers
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Washer doesn't drain or spin
remove bottom panel dip as much water as possible out if possible lean washer backward to keep as much as possible away from pump inlet remove clean out port plug by turning counterclockwise clean debris from pump impeller
Jun 05, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint WD420 - Stuck in wash cycle
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
Oct 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Inlet/Drain light keeps flashing
Kenyanjoe, I have had the same problem with a G638 . the inlet/drain light flashed 30 sec after start up, (the machine must empty on start up, this did not happen), This caused it to lock out on alarm I removed the drain hose from the S trap,removed the non return valve from the filter, check the drain pump impellar is free, then blow down the drain hose back into the dishwasher to make sure it was not blocked then found the drain pipe on the S trap under the sink was restricted causing the machine not to empty in time for the cycle to continue causing it to lockout on inlet/drain alarm. Have a go , good luck. GUNNO
Aug 14, 2007 | Miele 24 in. G693 Free-Standing Dishwasher
Miele 24 in. G665 Built-in Dishwasher Logo
936 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
