Question about Kenmore Dryers
Holes in Clothes from Dryer
Our 7 year old Dryer seems to be making small 1/4" holes in some our clothes. In addition the small heating vent in the back (inside) of the dryer is running extemely hot and has darkened. It also seems rougher like the enamel or coating has worn off . However, the holes in the clothes are not showing actual burn marks that you would expect. Any ideas?
  • jabelligball Jul 13, 2008
    The surface of the vent on the heater box seems to have a sharp area were clothes may be getting caught. Thanks
    Champion:
  • 210 Answers
Clean dryer vent. check the inside of drum for sharp points and the back for proper seal.
Posted on Jul 12, 2008
Clothes with pin holes are seen afetr washing/drying with He2 plus/He Washer dryer combination
Are you over loading the dryer? I know those combo machines can't dry a lot at once
Apr 28, 2012 | Kenmore HE2 Plus Front Load Washer
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
Holes in clothes
I'd bet the holes are the same size as the holes in the dryer tumbler. the only thing I can think of is that your dryer isn't tumbling and the heat that is pushed through the holes is burning your clothes.
Apr 18, 2009 | Miele Novotronic Premier 500 Front Load...
Holes in Clothes
You'll need a drill with a wire brush attachment and take that to the front of the heating element. The heating element gets a lot of crud built up on it and yes it'll put holes on clothes.
Apr 02, 2009 | GE DWSR405EBWW Electric Dryer
Dryer heats with smaller loads
1. unplug your machine and rach as far in the exhaust part of the dryer to see if there is an obstrucxtion
2.Take out the lint filter and make sure there are no gaping holes in the screen
3. Check the exhaust house leaving the machine or blockage, this hose should not run more than ten feet for optimal drying time.
4. its your heating element
Jan 19, 2009 | GE DBXR463EBWW Electric Dryer
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Inside of the dryer is cracking- huge holes!
the drum can be replaced but dont know if you want to pay for one they are probably expensive and 2nd if it is taking 2 to 3 times to dry clothes you have a vent problem which has caused the cracking of the drum probably cause so much heat build up in the machine your vent is stopped up and it isnt keeping the heat and moisture in the dryer which is a fire hazard please call a technician and please rate this
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown burn spots on Whites
Hot spots in the drum perhaps. Check for a loose heating element.
May 06, 2017 | Dryers
Clothes don't get dry
ckd rear vent hose be sure it is not flat and kinked try a load with vent disconnected if works ok ck vent all the way to the outside for blockage
Jun 03, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
155 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
