Question about Philips DVP3140
Input/output drama Ok...at home with my DVP3140 I use the red white and yellow cords. Easy. Here at my friends they have red blue and green cords which is coming from the wall not directly from their tv. I tried them in their respective color slots, as well as the red white and yellow spots, but I can't seem to find the right combo. I'm getting a no signal. Any ideas? Thank you
  • 3 more comments
  • kw8888 Jul 12, 2008
    Yes the other end is right and tight
    Everything is on
    Still nothing
    So put them in their respective colors and then what do you change on the tv? Thank you
    Thank you...on the dvd player the red is in the red pr, the green is in a green pr, and the blue is in a Y. The other ends are through the wall as the TV is a flat with no cords. Every input option on the TV says no signal or is a blank screen
  • 796 Answers
The red and white relates to the audio pins and the yellow is the video pin...
then main thing is audio can be connected in either pins that come from the wall but only the video needs to be perfect....
so why dont you try by inserting the yellow pin in all the sockets on the wall...surely it must be the first or the last socket...middle will be audio obviously.....
if you are still not able to get the signal...then there is some disconnect between the tv and the wall socket connection...you should be checking dat once you are tried with this option..
thankyou
Posted on Jul 12, 2008
  • 6,487 Answers
Have you tried checking the user manual? check this link for the user manual http://www.p4c.philips.com/files/d/dvp3140_37/dvp3140_37_dfu_aen.pdf
Hope that help a bit....
    Guru:
  • 859 Answers
Your TV will have several video source inputs and at the TV's control panel, where Brightness, Contrast, etc are found, there is also a video source selector as well, You will need to figure out which set of inputs are which video signal for your TV.
For HDTV, if your TV does not have a HDMI cable input, you want to use the component in, these are the red, blue etc.hook those up and then cycle through the video input choices on the TV's control panel until you are getting a signal from your DV player.
If you have lost the manual for your DVD player or need more help go to this page where you'll find users with the same player. There is a forum here too.
Regards,
Worldvet
  • 2,427 Answers
Well thats cause they are different inputs, red, yellow white - rca
red blue and green = component,
you have to connect them via the component outputs on the dvd player,, you then need to enable it on the tv in the setup menu
  • 3 more comments
  • Rishi Roshan Ali Jul 12, 2008
    in the tv, ebnter setup then menu, look for video or input settings, then enable Component Video Input
    Use your Tv manual for a refrence
    WARNING do not mix up the rca red with the component red
    Then there is a problem with the cables, try changing the cables ,, you can use the rca cables as component, just ensure its color to color no matter the cable color is different
    The cables may have an error, try using a different cable, the rca cable can be substuted as a component, even the if the cable colr dont match with the jack color you can still use it just ensure the cable is in the correct jacks,, If there is an input to the frount of the tv or the side try that first.. if not you will have to mount the tv from the wall and see if the connections are correct
    Genius:
  • 1,011 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sir,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Connecting to television
IMPORTANT!
– You only need to make one video
connection from the following
options, depending on the
capabilities of your television.
– Connect the DVD player directly
to the television.
Using Composite Video jacks
(CVBS)
A Use the composite video cable (yellow)
to connect the DVD player’s TV OUT
(CVBS) jack to the video input jack (or
labeled as A/V In, Video In, Composite or
Baseband) on the television (cable
supplied).
B To hear sound of this DVD player
through your television, use the audio
cables (white/red) to connect AUDIO
OUT (L/R) jacks of the DVD player to
the corresponding AUDIO IN jacks on
he television (cable supplied).
ThanksGood Luck
"Don't forget to rate the solution"
    Guru:
  • 1,894 Answers
Ensure the signal source is turned on
and please have the manual before you make the connections
    Scholar:
  • 135 Answers
Hello sir,,
Are u sure the red blue green chord signal is connected properly to the source of the signal?
thank u
  • Harrish Mugundhan Jul 12, 2008
    hello hi
    The red (not "Pr) & white ports are for sound, you will need to connect those. Look for the matching red & white sound ports on the TV. They will be there. Keep looking. To send the picture information to the HDTV, a DVD player can either use a yellow (composite) cable or the blue, green, and red "Pr" (component) cables. (Note: the red "Pr" cable/port is different from the red sound cable/port) The blue, green, and red component cables will give you a better picture quality. I've never heard of a HDTV that didn't have a yellow video input. It's a lot easier to find if you look in the owner's manual than to get on your hands and knees with a flashlight and magnifying glass to figure out which port is which. Most DVD players, including my $30 one, have green, blue, red video outputs. If yours doesn't you might want to think about buying a new one. Getting a black & white picture probably means you mixed up the color codes on the video cables. Go back and get them to match the color codes. Perhaps you have one of the green, blue, or red video outs connected to the TV's yellow video input.
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
When playing a DVD, I get sound but not a picture. The message on the screen is no input, check input. I have checked the cables at the DVD and at the TV and both are connected correctly, i.e. red to...
Have you tried using standard RCA AV cables? yellow-red-white - to TV. Or have you tried using an S-Video cable (a 5-pin mini DIN plug) between your DVD player and TV? if your TV has S-Video input, and your player has S-Video output, a cable for this should be easy to obtain and connect. Not expensive either.
Your TV should automatically detect the connection of S-Video (if it has this feature). S-Video is better quality than standard RCA yellow AV cable. (you can leave the existing component video connected)
You can also check your DVD player 'setup' maybe it is incorrect - make sure when using component video (red-green-blue) to set the player's output to progressive (for a TV that supports it) - unless it is already set to this.
If everything in the setup menu checks out OK, go with the cheap and easy S-Video cable suggestion. Radio Shack may sell these.
Apr 04, 2011 | Sony DVP-NS575P DVD Player
Is i possible to connect a rca cable to the converter box from a dvd player and watch on the tv?
DVD players can have several outputs:
* coaxiable cable
* composite video (RED/WHITE for stereo audio, and YELLOW for video)
* component video (RED/BLUE/GREEN to video components, plus RED/WHITE for stereo audio)
* HDMI
TVs can have several inputs:
* coaxiable cable
* HDMI
Just use the correct tables to "match" the output to the input.
Feb 21, 2011 | RCA (DTA800B1) Video Converter
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
DVD's not playing in color
sounds like the problem is the TV . your tv have to different inputs , COMPONENT is for the separate color , BLUE , RED , GREEN this is for better video quality , if your DVD doesnt have this OUTPUT feature , then maybe the YELLOW (VIDEO) , RED & WHITE ( AUDIO ) thats coming out from your DVD player is connected to the COMPONENT input of your TV , GETTING the B&W effect. it should be connected to the VIDEO input of your TV ( yellow , red , white ) hope this is helpful AJ
May 03, 2009 | Philips DVP3140
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
How do I get sounds when I use the red green blue rca hook ups?
The red, blue and green RCA hook up is just video. You must also use the red and white pair of RCA jacks for the audio. You can usually find the audio red and white jacks right below the video red, blue and green RCA jacks. Get yourself an audio RCA cord with the red and white connectors and run that from your video device audio output to the audio input of the TV that corresponds with the video input of the TV. An example would be if the red, blue and green are on the "Video 1" input of your TV you will find the red and white audio input for "Video 1" right below or right next to the video inputs.
The red, blue and green video jacks are called "component video" and they only have a video signal for high definition video, so you must also run a separate audio line for it. The same holds true for the yellow video RCA connector, that one is called "composite video" and it also has only a video signal with no audio.
I hope this helps, if so a "FixYa!" rating would be very much appreciated.
If you need more help just post your concerns right here onthis thread.
Dave
Nov 28, 2008 | Initial DTV-171 17 in. TV/DVD Combo
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
Philips DVP3140 Logo
123 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
