Question about HP vs15 15"LCD Flat Panel Monitor
Monitor the whole image on the screen is shaking. I have the changed the screen refresh rate to and it has gotten much better, but still not steady
    Scholar:
  • 136 Answers
If you are using windows, there is an option to show only refresh rates supported by the monitor. Start with 60hz and go from there. Remember that the bigger the resolution, the smaller refresh rate it will handle.
Posted on Oct 11, 2008
My compaq presario sr1620nx screen is shaking
Look for your computer's monitor settings, then adjust its refresh rate.
To modify a refresh rate on Windows, right-click anywhere on the Windows desktop.
Select "Properties," then choose the "Display Properties" tab on the window that appears.
Click the "Settings" option, then select "Advanced" from the window that appears.
Choose the "Monitor" tab, which lets you access a drop-down menu with the options for refresh settings adjustments.
As a basic guide, use a setting of at least 75 hertz.
Confirm the change by clicking "Apply." Reboot the PC to ensure the new settings on the screen take effect.
Check your screen if the blinking problem is resolved. If not, try a higher refresh setting.
If there is no change on the flickering of the screen, this means the problem is not caused by the screen's refresh rate.
If your computer is not running on a battery or surge protector, shut it down to safely transfer the plug to another outlet
Hope this helps.
Nov 27, 2012 | HP Compaq Presario SR1620NX...
The images on my computer screen shake back and forth making it difficult to read. I tried hooking up my screen to another computer and the images were fine. Some one suggested to me that it may be the...
First step, Go into your Control Panel and find the Display settings. In the display settings there should be a tab to adjust the monitor. Try changing the Screen refresh rate. Also, make sure you have the latest drivers for your video card and operating system.
Apr 05, 2011 | Computers & Internet
Monitor flikkering .i will check the VGA cable and power cable both are properly connected but the monitor is flikkering .what i do
Answer Sometimes if the refresh rate isnt set high enough you will see a noticeable flicker on the screen .. to change the monitor refresh rate .. you can right click on the desktop and then left click on properties .. click on the setting tab then click on the advanced tab then click on the monitor tab ..look in the drop down menu where it says 60 hertz and see if the refresh rate can be changed .. if it cant .. uncheck hide modes the monitor cant see and then click on the drop down menu .. pick a refresh rate .. 75 hertz is what i use and it should stop the flicker
Answer
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Answer
A nearby device can cause stray magnetic fields that will cause the display to be affected.
A problem inside the monitor will cause the display to have problems.
If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
Answer well one major cause can be the weakness of the electron gun that fire electrons on the silicon plate (pixels) that produces image on the screen so there must be some problem in electron gun in my view
Dec 14, 2010 | Acer AL1511 15" LCD Monitor
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
How to troubleshoot flickering, jittering, shaking, or wave-like images on a LCD monitor. 1) Connect the display to the computer. 2) Turn on the computer.
Any monitor has something called a screen refresh rate. If you are replacing your old monitor with a newer one, there is sth called a screen refresh rate that you need to configure. Older monitors (size also matter) have a lower screen refresh rate than the newer ones. If that happens to be your case, find the refresh rate of your new LCD on its manual and adjust it like this.
  1. Right click on an icon free area on your desktop.
  2. Click Properties
  3. On the Property dialog click on the Settings Tab
  4. At the bottom of the form click on Advanced
  5. On the coming property dialog click on the monitors tab
  6. Under Monitor Settings you will find the screen refresh rate combo box, here select the rate that suits you screen and click apply.
  7. confirm your actions in the confirmation window.
Note: Be sure to select a screen refresh rate that matches your screen. If you select a rate bigger than the LCD's capacity you will end up with a black screen on your monitor and won't be able to see the desktop unless you boot in safe mode.
Nov 25, 2009 | Sony VAIO VGN-CS220J/W Notebook
Dell laptop monitor jumping
Could be your refresh rate. Try the following:
* change your monitors refresh rate to higher availible.
* rt click on desktop then on properties and then display setting and then advance and then click on monitor tab and choose the highest availible and then click ok.
Would also attempt to move the screen forward and back to see if you have a pinched cable.
Also attempt to connect to an external monitor to see if it is your laptop monitor or the video card causing the problem.
Hope this helps.
Oct 25, 2009 | Dell Vostro 1510 Laptop
Screen Shakes on High Resolutions
your rate of refresh is too high, it's refreshing too fast, you need to lower the screen resolution. keep in mind, the tv resolution is much much smaller than a computer monitor. a computer monitor has much higher resolution. so Tv can only handle so much in resolution. if you need a better picture, it always the best to buy a monitor, not a tv for computer to get a good picture. if you have any more questions, let me know.
Oct 17, 2009 | Televison & Video
I have a microtek 17' monitor model is 41f
This can be caused by low Screen Refresh rate. Eg 60Mhz. To increase this go to Display propertes > Setting > Advance > Monitor > Screen Refresh rate
Your graphic driver must be installed correctly to be able to make this change.
Please tell me If this dont fix
Best regard
Dec 05, 2008 | Microtek Computers & Internet
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
HP vs15 15"LCD Flat Panel Monitor Logo
134 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
