Sears Kenmore Amana window ac unit 13,000 btu: Sometimes the compressor will not shut off to cycle. Last night I woke up to an ice cold house and turned the digital temp up and the compressor wouldn't shut off so I turned the power off and the comp stayed running until I unplugged the unit. What does it sound like to you?
  • leorousseau Jul 12, 2008
    Also, know when I plug it back in the compressor is binding up trying to start. It's like it is stuck engaged.
  • 3 Answers
Sounds like a dirty coil or stuck thermostat
Posted on Jul 17, 2008
When I woke up this morning, the fan on my Amana SCD23VW was running but the compressor was not. I thought it might be in a defrost cycle, but 30 minutes later it was still doing the same thing, and the...
If the fan is running its not in the defrost the fan doesnt run then.
the things that could be the problem are;
the compressor fan is bad so compressor over heats and shuts off
the relay on the compressor is burnt so the compressor wont start
the compressor is bad
i would suspect the relay first..the fan by the compressor secondly and finally last the compressor ..its the least likely thing to go bad
Aug 29, 2011 | Amana SXD524VW Side by Side Refrigerator
Kenmore 65234 bottom refrigerator has a hum/rattle for about 30 seconds then quiet, then after a couple minutes, it does it again. Sometimes for an hour this repeats and sometimes does it for a few cycles...
Might be the compressor relay is fixin to depart this life. themobilian_1937.jpg
If this relay starts sticking all the windings will remain active and overheat the compressor. The overload will tae notice and shut the whole shebang down. Once it cools and makes contact the circus continues until the relay finally disintegrates. The last death throws will be a constant clicking followed by noticeable cooling loss in the ice box.
Amana bottom mount service Manual
Mar 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
My window a/c compressor won't turn off, thus making the room extremely cold.... Kenmore 17,5/18000 btu model 580.73189300. Earlier, the front grill was iced over and i have since thawed it out (the 1st...
the unit running all the times sounds like a faulty thermostat which is saying its still hot when its not.try finding thermostat make sure all plugs are in all the way on the circuit board. does it run all the time on heating? the iceing up would just because its running all the time. i
Nov 10, 2010 | Kenmore 75180 Wall/Window Air Conditioner
I have a new kenmore ac unit model 580.75101500 i bought about two weeks ago and installed last week. its been blowing ice cold as it should no problems until today. Now the ac turns on runs about 5...
Take it back or call Sears. A 2 week old unit should not do that. I'll assume the settings are right like set on AC Auto or Max cool and not just fan. Are the coils icing or were they icing behind the filter? If not, I think it may need to be serviced.
Aug 07, 2010 | Kenmore Heating & Cooling
Amana fridge/freezer compressor problem
Unplug unit.
It's not possible to tell which without replacing the starting system. Hard start kit would be fine. RCO410 is common. If it starts the unit the next check would be an ampmeter clamped onto one of the power leads. The ampmeter for refrigerators of that age may read around 2-5 amps when running. If it's much higher than 5 Amps after it's running be prepared to replace the compressor. Maybe it won't quit today...but it won't last with high amperage. If it doesn't start with this kit you need compressor.
Sep 08, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore AC compressor on and off while outside unit fan running
If the out door fan keeps running and the compressor cycles off that would be the overload in the compressor.
What keeps the windings cool is the refrigerant back to the compressor.
For the overload to cycle it would have to be either not enough cooling back to the compressor or high amp draw, which could be the metering device (txv or orifice) or low on charge, or other things would be a bad capacitor, sometimes a bad start relay not staying open, when compressor gets up to speed or anything causing the compressor to draw high amps.
To check the refrigerant, he needs to check the superheat at the compressor it should be appoximately 12° to15°, and next time the compressor goes off if you shut the power off and feel the top of the compressor and if it's hot 130° or higher it's probably refrigerant.
Aug 14, 2009 | Heating & Cooling
Kenmore 76081 cycling rapidly
check voltage when it shuts down possible motor overheating
Mar 09, 2017 | Kenmore 76081 Wall/Window Air Conditioner
AC changes temperature by itself!
If it's not some sort of built in economizing feature, someone else isn't getting up and changing the temperature while you are asleep and the air conditioner fairy is playing tricks, then the control PCB is in need of repair and will have to be repaired through a sears authorized repair center.
I am a bit surprised that it will allow you to set the temperature to a low 70 degrees as this is pushing the limits of an air conditioner. They tend to freeze the coils at around that temperature.
Jun 07, 2008 | Kenmore 75050 Wall/Window Air Conditioner
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Heating & Cooling Logo
140 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
