Question about Philips 42HF7444T 42 in. Plasma TV
Tv switching off on its own without any one tourching it
My 42" philips fla tv is always switching off when am watching it and anytime this happens i have to switch everything off take all the plugs out for some time and the try to switch it back on then it starts working ok for some time and switches off again.
I have slightly different problem. The TV "switched" off suddenly when I changed the channels too many times. Will need to turn off the main switch power off for a while before the TV can be turned on again. A very irritating and mysterious problem. Wondering if there is any fix to this problem?
Posted on Jul 26, 2008
I have had my TV-- a 42" Philips plasma-- for
it can be a poor contact or puffed capacitor in the power supply board
Dec 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
Whats causing horizontal lines in my philips 42 in. plasma tv? seems to be 4 sets of lines with about 15 to 20 lines in each set. Also has the red vertical explosion from images on the channel im watching.
There are very fragile ribbons that are attatched to the top of some LCD displays, if these have been pinched or damaged in anyway, this can create what you are describing. Was the LCD panel ever hit by like a wii remote around the tv bezel or did it fall without cracking the screen? It could be something simpler like, some really wrong color settings or something...
Jun 14, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
I have a 42" Philips Plasma HD tv and today it has been cutting off every few hours, its not the first time but it doesnt always happen either. When it goes off I just press the stanby button and it boes...
Well it could be that your fan is blocked and or clogged.You can take a tweezers,turn the television upside down,and lightly pluck out the pieces of **** clogging it up.That should make your fan run and then your television wont overheat and auto-shutdown.Hope it helped
Oct 15, 2009 | Philips 42PFP5332D 42 in. Plasma...
TV will not go into standby mode
You may have to unplug the tv from AC power for a few seconds and then reaaply the power! Or replace the small signal board.
Sep 13, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Why do I see bluish light on right side of my philips plasma 42 i
Inside your television are 3 different sets of pixels (red,green,blue) If a pixel goes out or actually stays on there is no way that that can be repaired/replaced. Pixels are considered to be part of the panel of the tv and it is more cost efficient to replace rather than repair. Call your manufacturer immediately. See if you are still in warranty and perhaps they can replace your unit.
Aug 04, 2009 | Philips 42FD9954 42 in. Plasma HDTV
CAN'T TURN ON MY PHILIPS 42FD9925/01 SCREEN, ALWAYS IN STANDBAY
Did this solution work as I have the same model and same problem and I have ordered the remote from philips suppliers
Jun 20, 2009 | Philips 42FD9932 42 in. Plasma Television
Green screen
I am a TV repair technician and what you are experiencing with your plasma and PS3 is a HDMI compatibility problem. The Philips plasma and the PS3 electronic handshaking (EDID) are not right. This happens alot with an older version of HDMI like 1.1(Philips Plasma) and a newer version of HDMI 1.3 (PS3). A tv firmware or PS3 firmware update will not resolve the problem. I would recommend using the HD component video cables and that should work just fine for playing High Definition BluRay movies.
Oct 05, 2008 | Philips 42PF9966 42 in. HD-Ready Plasma...
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Philips 42HF7444T 42 in. Plasma TV Logo
290 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
