Question about E-Machines T6528 PC Desktop
Troubleshooting in the post
When I power on my pc in the post it upper
REV P1.2RL
Main processor: intel pentium(R) 4 2.80 GHz
the memory test did not run and the post will jam.
On the bottom there ara Del to enter in the setup and ESC to skip
but nothing of those are working.
  • simonv Jul 12, 2008
    The keyboard doesn't work could be the battery of the motherboard or the ram because the red LED of the tower case remains lighted in the post
    Thanks for the other information but I will use it at a last result because I don't want to lose some data
  • 177 Answers
Try getting to the setup when you switch on by pressing F2. Choose CD Rom as first drive. Reboot and use the recovery CD that came with your PC.This should put it back to the original factory settings.Note* You will lose all data you have on your PC.
Posted on Jul 12, 2008
SE PUEDE CAMBIAR EL PROCESADOR PENTIUM 4 POR UN PENTIUM D LA PLACA (929 REV 0G S25
this is an english only forum.
google translate works, try that?
here.
THE PENTIUM 4 PROCESSOR CAN BE CHANGED FOR A PENTIUM D PLATE (929 REV 0G S25
THE PC IS A COMPAQ DC 7100. I HAVE CHANGED THE PROCESSOR FOR ANOTHER FIRST OTHER PENTIUM 4 OF 3,200 GHZ BUT IT DOES NOT WORK WELL PROVE WITH A PENTIM D AND I WILL NOT AND NOTHING I HAVE TRIED TO PUT YOURSELF AND I REMEMBER THINGS TO RARE AND DO NOT START.
why do that, what caused you to start playing with processors.
you can NOT just throw in any processor you want
the HP documents long gone now on this old old relic PC
tells you what processors this PC supports.
usually just a one class and just 5 or so in a class.
if you google your PC you find these words
: Intel 5 Series (Pentium 4)
see that 5 there, only this series works and only those allowed
by HP in that series work.
no boot
why not put the PC back as you found it.
the post, why does not PC not boot and know its not the processor 99.99% of the time .
step 1 is power, do you have full DC power out of you PSU
2 yes, does the monitor test out ok on other PC.
3: does the BIOS screens work.
yes,yes and yes, means the HDD software is corrupted or or the HDD is dead.
to test any HDD I use Knoppix live DVD to test it.
i see this too
there are 4 PCs with that model , the service tag shows p/n::
this code tells the helper what motherboard is there and what processors are used.
ok i found the page that shows how to decode the p/n on service tag.
old old lost book, see code 560 there, ? bingo.
https://www.manualslib.com/manual/72042/Hp-Dc7100.html?page=4#manual
Aug 08, 2017 | Compaq Computers & Internet
Required Intel SL9CB Pentium, 3 GHz compatible motherboard
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
Pentium 4 HT, Model 531. sSpec number SL9CB.
OK. So far I know you need a motherboard that has an LGA 775 processor socket; needs to support Intel processors that are Single-Core, and with an 800MegaHertz Front Side Bus.
(800MHz FSB)
Ram Memory? Dunno. K
Do know the rule of thumb is, that the Ram Memory typically operates at Half of the processor's FSB.
Therefore can only assume the ram memory is DDR Sdram, and operates at 400MHz. (PC-3200)
You haven't stated the motherboard chipset that was used, OR what computer manufacturer, and model number; this mobo came out of.
(MOtherBOard)
Also didn't state if you are using a graphics card, and what kind it is.
(PCI, AGP, or PCI Express)
This isn't a 'guess-ti-mate'. Exact specifications are required in order to replace the motherboard.
Otherwise you may not be able to reuse the Ram Memory, or graphics card. (IF used)
Awaiting needed information. Post back in a Comment.
Regards,
joecoolvette
Oct 30, 2012 | Intel SL9CB Pentium, 3 GHz
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
I have a Pentium 4, 3.00Ghz 3.01 Ghz desktop and wish to upgade its am memo fom 500 mb to 4 gb or even 8gb. Is this possible? and what memo should I look for on ebay ?
You need to find the motherboard manual with all the specifications in
to find out what type to use.
Also note: There's no point putting more than 4 gig in if you only have Windows 32 bit.
Jan 25, 2012 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
I just need to figure out what the socket type this motherboard has for the processor so that I can find what processors I can upgrade my computer with. It's a g45t/g43t AM 3 V: 1.1 motherboard made by...
The socket type of ACER G45T/G43T - AM3 V1.1 motherboard is LGA 775. Here are the compatible processors you can use for this motherboard :
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Sep 13, 2011 | Computers & Internet
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
Mar 22, 2011 | HP Pavilion a775c (A775CB) PC Desktop
Is it possible to upgrade to a faster processor on a hpn pavallion dv1000
here is a list of processors supported on that machine
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
Mar 15, 2010 | HP Pavilion dv1000 Notebook
Turned off PC one night working fine. Next time try to use, PC wont boot. No video display, no bios, no posts, nothing. Gateway Desktop GT 5464 w/ integrated video, Intel E2140 Processor, Intel 945GC Mobo....
Have you tried booting it from yor CD drive with bootable software?
Any led flashing anywhere in the computer?
If not, we are talking about energy problem. Try fitting the energy cord firmly, try connecting the battery charger in a different power outlet.
Aug 26, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Hi, I have HP dv4000 model, Intel Pentium 1.60 GHz processors, Can I upgrade the processor? And what is the maximum upgrade for the processor? Regards, for more details and features...
According to the service manual, these are the processors your notebook will handle:
Part#
Intel Pentium M 2.13-GHz 396700-001
Intel Pentium M 2.00-GHz 396699-001
Intel Pentium M 1.86-GHz 393327-001
Intel Pentium M 1.73-GHz 383474-001
Intel Pentium M 1.60-GHz 383473-001 and 396698-001
Intel Celeron M 1.50-GHz 383471-001
Intel Celeron M 1.40-GHz 396697-001
Intel Celeron M 1.30-GHz 389036-001
So it looks like the Pentium 2.13GHZ is the top one.
Here is a link to the service manual for reference: This is on page 5-24.
Thanks fro using Fixya. A Fixya rating would be most appreciated.
Jan 26, 2009 | HP Pavilion dv4000 Notebook
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
E-Machines T6528 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
