Hi, problem can be solved..might not be able to really give you full help, cause the details you gave is not a 100% detail for me to give you a 100% answer.
I will give you possible solutions to the problems .
When a speaker does not give you low ends, it might be because the crossover controlling the output of the speaker(low).You will need to open up the speaker and test the fuse inside if speaker..
Also it depends on what the speaker is connected to, is it's an EQ or a Mixer, You can cut down high frequency from both the EG and Mixer.. i guess that will do..
And make sure you when ever you connect the speaker you use a mono jack or a speakon plug for good quality sound.
Hope it helped..
Feel free to pass on your comment ..
Thanks for using fixya...
