Question about SanDisk Sansa Clip MP3 Player
Not working my sandisk shows nothing when the it is turned on....its display is fine as it works normally when it is connected to the wall plug ..but as soon asit is removed from the plug it is not working. i have used it for 2 months
  • ash3291 Aug 15, 2008
    only works when plugged up
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
Hcm 582 monitor not display show
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Apr 23, 2014 | Acer AC713 17" CRT Monitor
Can I use my Sandisk Sansa C240 while it is charging?
This is normal when the Sansa is connected to a computer. You can use it while charging if you connect it to something else. For example, you might have a cell phone with a USB charger that plugs into a wall outlet. You could connect the Sansa to it, and it would let you listen while charging.
May 01, 2010 | SanDisk Sansa c240 MP3 Player
Wondering how long it takes to charge the Sansa Clip MP3?
I have had the same problem. It seems the radio never turns off and keeps drawing power. Solution: before charging, go to a song, start it playing, then pause it, then turn off the sanza clip. Plug it in and it should charge up fine.
Mar 22, 2009 | SanDisk Sansa Clip MP3 Player
Display problam
  1. Make sure that the monitor is turned on and has power. Make sure that the display's power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Check that all video cable connections to the computer video port and to the monitor are properly connected.
  3. Examine the pins on the video cable connector to make sure they are not bent or damaged in any way.
  4. Connect a known working display (if you have an extra one available). If you see video after doing so, replace your old display.
  5. Unplug the video cable and then turn on the monitor, check any message is showing in monitor if its shown means ur monitor is ok or else their is a problem in monitor..
  6. turn off the system and check the ram..
  7. Reset the computer...
Jan 28, 2009 | ASUS MB M3A78-EMH HDMI RT Motherboard
Won't turn on
how old is the system
could be your internal plug for ac may have become lose from plugging and unplugging
or you may just need a new ac cord
try moving it around where it plugs into the laptop if you get a brief connection then it probably is the connection inside the laptop they can be replaced
Jan 16, 2009 | Computers & Internet
E260 Wont Turn On
on the desktop click right button and click properties.now go to the apperance below the windows and buttons chane it as windowsxp style.
Jun 14, 2008 | SanDisk Sansa e260 MP3 Player
Won't turn on
Sometimes it is the battery not holding the vharge. If that is not the case then it most likely is the adapter connector on the mother board where there could be a broken solder connection or the connector itself may be broken. I had the same problem with my hp laptop and disassembled it abd found a broken solder connection to the motherboard and the adapter connector. I just made a solder connection where it was broken and everything came on normally.
Jun 10, 2008 | Computers & Internet
My display on the dmr-e50 shows ready but will not turn on.
UNPLUG UNIT FROM THE WALL SOCKET & REPLUG AFTER 12 SECONDS.
Jan 23, 2008 | Panasonic DMR-E50 DVD Recorder
SanDisk Sansa m230 MP3 Player
maybe the internal battery is shorted,leaked,low. i remove it and start working well.
Aug 05, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
