Question about Admiral AAV7000A
Water When I fill the machine with water, all I get is hot water, know matter if it set to cold. What is the problem? I have checked the hose to the water supply and it is set up corretly and the water is on.
    Sergeant:
  • 225 Answers
It could be a blockage either at one of the valves in the cold supply line, or at the gauze filter where the inlet hose joins the machine, or it could be the inlet valve solenoid itself which has a problem.
Have you had work done on your water supply lately? After a supply pipe burst there is often a lot of grit in the pipes, and this collects in your valves.
If you turn off the supply to your machine and then disconnect the cold pipe to the machine you can put the end in a bucket and turn on the water just a LITTLE bit to see if there is water available. You'll also see if the gauze filter is full of grit. If no water comes out try turning the various valves in the line closed and then opening them again a few times - it's best to have someone holding the end of the pipe in the bucket!
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Posted on Jul 12, 2008
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
I have a lime.stoppage in the washing.machine or hose, where do I start? It is not.the.wall faucet. I tested it.
check/ replace the inlet solenoid valve unit in the machine
if it is faulty or not getting power then the water will not flow into the machine.
simple test is to change the hot water hose to the cold water tap and use hot water setting with the cold water tap on
if the water flows then it is the cold water solenoid
Mar 18, 2015 | Washing Machines
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
My washer no longer produces cold water, only hot, except for the start of the cycle. The machine will tell me that it's not getting cold water. It doesn't matter whether I set the water temperature at...
It sounds like the fill hoses are inverted. Most of the Fisher washers only fill with cold water after the initial fill. So if the hose are inverted then it will only fill with hot. Beyond this I'm at a loss. Good luck
Apr 23, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
I am about to buy this model machine but before i do i need to know-does this machine heat up the water itself? or do i have to have a supply of hot water going into the machine in order for it to be hot...
I think you will find that all washers are able to heat water. If they are hot and cold fill, they use the heater if the hot water supplied is not hot enough for the particular wash. If they are cold fill only then they need the heater for all non-cold washes.
If you purchase the washer you are thinking of and it is cold fill only, it will have only one inlet hose, the cold water one and it is a straight forward installation- hose from washer screw into cold supply tap.
If it is hot and cold fill you have a choice- either go to the expense of plumbing hot water to it OR purchase a 'Y' 'tap' adapter. The adapter screws onto the cold supply (by the 'bottom' of the Y) and the hot and cold hoses which go to the washer are screwed into the (top) 2 ends of the 'Y'. The washer opens its hot valve, gets the only water supply which is cold through what it thinks is the hot hose and heats it up accordingly. When it wants cold it opens its cold valve and gets the cold water through what it thinks is its cold hose- which it is!
I hope this clarifies the situation for you and if it has please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 18, 2011 | Washing Machines
No matter what cycle I set the washing machine, I only get hot water. There is no cold/cool water. Any ideas what could be causing this?
Yes the cold water solenoid in the fill valve is not working. the cold and hot valves are made together so you will have to replace the assembly but it's not the hard and not that expensive
PS before replacing valve shut off cold supply at the wall and then remove the cold hose from the back of the washer and check the (inlet screen) for debris that may be blocking the flow of cold water
Dec 23, 2010 | Kenmore 22422 Top Load Washer
I set the water temp setting to cold, but it keeps filling with hot water. No matter where I set the dial, it fills with hot water.
check whether the hoses are mismarked when they come out of the wall.
the same thing kept happening to us (whirlpool cabrio) and i checked the temperature on the hoses coming out of the wall - cold was mislabeled as hot by the builder, and vice versa.
Aug 31, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Hooking up the cold and hot water in back of the washing machine
In a word Yes!!
The machine will fill with Hot water to rinse and if that water is as hot as the normal supply your clothes will shrink and the colours will run.
You need the hoses and the supply to the hoses to be correct so that when you put it on a cool wash it fills with cold water and brings the temperature up to the right level.
Bringing in hot water will kill the soap powders action.
Also the machine adds hot and cold water to make sure that it gets a correct balance for other programs
If you are not sure how they are connected then look at the back of the machine, there should be either a H and C stamped into the backplate or the inlets are Red and (White or Blue).
If the hoses coming from the fawcets are the same colour then take one off the machine place the end in a bucket and turn the fawcet on , if it does not get hot then its the cold one so then make sure it goes back onto the C or the White connector
Jun 22, 2009 | Hotpoint Washing Machines
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Admiral AAV7000A Logo
44 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
