Question about Dopod 838 Smartphone
Dopod 900 i have o2 xda exec ... cannot on ...only black screen ... battry is ok ... cannot go to bootloader ... ithink all data bios and memory lost ...can u help me
    Problem Solver:
  • 3 Answers
I have problem cannot on ...only black screen ... battry is ok ... cannot go to bootloader ... i think all data bios and memory lost ...can u help me
Posted on Jul 13, 2008
I have a xda exec phone .the screen is blank with a serial up and 1.0v down the screen .. pls tell me what to do ..
Your phone is in bootloader mode. If you have not intentionally put it in that state, it might have entered it after an usucessful ROM upgrading process. Anyway, to get out of that state, just soft reset your device. The reset pin is located at the left side (in portrait mode, or at the back of the phone, when its screen is slided open). Just lightly press that pin with the stylus pen.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Feb 27, 2012 | O2 Xda Atom Exec Smartphone
How can i align screen in o2 Xda Exec
1. Tap Start > Settings > System tab > Screen. 2. On the General tab, tap Align Screen, and follow the instructions on the screen.
May 06, 2010 | O2 Xda Atom Exec Smartphone
My Dopod 900 (aka O2 Xda Exec) White Screen Problem
if you have a lot of data on your phone, do a sync. if it synched properly, if it does, probably the flex is damaged or the screen alone. try to press all the buttons on ur pda phone. if they all make a sound (if your sounds for keys are enabled, i hope) your flex is alright. have your LCD changed. try to tap your screen also if it makes a a sound... Hoping to be of help to you.
Apr 13, 2009 | O2 Xda Atom Exec Smartphone
Factory reset O2 Xda Atom Exec Smartphone
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
Feb 08, 2009 | O2 Xda Atom Exec Smartphone
O2 xDA Atom Exec Screen Blank After SofReset
Couple of things you can try to fix the issue, firstly try a hard reset
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. *Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost
Try that and if it doesnt resolve the issue then we can try another solution
Aug 23, 2008 | O2 Xda Atom Exec Smartphone
O2 x2a
if my problem repair . of cors i pay you
Jul 11, 2008 | Dopod 838 Smartphone
O2 Xda Atom Exec cell shut down; can not turn back on. one time black screen white letters came on, last read said looking for usb port to down load?
The Black screen that you are talking about is the bootloader of your PPC. Its just like the BIOS of your Computer.
There might be some problem with the Operating system of your O2 Atom Exec.
Try a hard reset by holding the Power Key and then soft reseting.
I know that you will lose your data, but you may get your PPC working back.
Please Rate if this is helpful.
Apr 22, 2008 | O2 Xda Atom Exec Smartphone
O2 xda exec
This is the suggestion they provide on O2 website for such problems:
  • Perform a soft reset (PDA phone) or re-boot the device (Smartphone) and test again.
  • Perform a hard reset (PDA phone) or return to default settings (Smartphone) and test again. (read below before dong this)
  • Check that the application still fails to execute after you upgraded the ROM (OS) to the latest revision. If you haven't upgraded your ROM (OS) do so now and check again.
But before doing the hard reset, I suggest you try installing other camera software for windows mobile 5 and check if the camera still working (not a hardware problem). If its still fail, try the hard reset after backing up all you data.
Jan 31, 2008 | O2 Xda Atom Exec Smartphone
DELL LCD monitor E151FPb turn white
I also tried re-soldering joint L781 on the main power control board (see Solutions #2 and #7). It worked. My 15 inch Dell flat panel LCD is working again, white screen gone. The solder around the pin did looked different to to the other joints...a very slight gap around the pin as though it wasn't contacting properly. To locate L781, look at the bottom of the PCB (the side with the soldering) with the power plug socket at the edge closest to you. L781 is in the top left quadrant of the board, about 2 inches in from left, 1 inch down from the top. For good measure, I also tried the solution that suggested trimming a millimeter of the end of the two data ribbons that plug into the smaller control board, although I couldn't see anything wrong with the data ribbons. I did this at the same time as resoldering L781 so not sure if it made any difference.
Feb 25, 2007 | LG 37LP1D 37 in. LCD Television
Dopod 838 Smartphone Logo
136 people viewed this question
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
