Question about JVC GR-D50 Mini DV Digital Camcorder
GR-D60EK importing data from camera to computer
I have a jvc mini Dv with the above ref no... How do i transfer pictures from this to a pc...do i need a special lead? All i have at the moment is a dvd lead and a scart lead.
  • weanmaz Jul 12, 2008
    thank you very much for the help...will look into buying a usb and hopefully will beable to transfer my images to computer.
  • 2,794 Answers
You need a cable. If your camcorder has a DV port you need a firewire port in the back of your computer as well as a firewire cable. If your computer has a USB port you need a USB cable.
You also need video capturing software to use it. Pinnacle Systems makes an easy to use system that work with your camcorder. Once the software is installed, the cable is plugged in and the camera is turned on, your computer will lauch Studio for you.
Posted on Jul 12, 2008
I have a new jvc gr-d820ek camcorder and the mains charger will not fit socket on camcorder. Ref on charger is AP-V14E
I have a jvc mini dv (model number GR-D820EK) and was not given a cd or a usb cable with it. I carnt transfer my footage over to my pc. Please HELP!!!! were could I buy the correct usb?????
Jan 11, 2010 | JVC GR-D73E Mini DV Digital Camcorder
Transfer movie from mini tape to computer - JVC GR-D770U
install first the bundled software with your camera turned on and plugged in to your pc and then restart your pc if its necessary..
Dec 27, 2007 | JVC Cybercam GR-D200US Mini DV Digital...
Can we turn this Mini DV into a cd?
through the data cable given and the pc suite given u hav to install the software and connect the cam and pc through the cable and transfer the data r u must goto the shop and convert it for money
Mar 17, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
Im trying to transfer viedeo from a JVC GR-DVM96 vis usb to mini usb. Do I need to use the dv port?
Hi, connect the cam and PC using 4 pin firewire cable (not USB cable).
Switch on the cam.
Open Windows Movie Maker and import the video from device.
Dec 29, 2008 | JVC Cybercam GR-DVM96 Mini DV Digital...
JVC GR-D870 digital camera, how to transfer Min Div tape to PC
Hi, You need to use 4 pin firewire cable to connect to the PC. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
I have a JVC mini dv camera model # GR-DVL 725U trying to find out how I transfer video to my PC any ideas?
Plug in yourcord to a usb port. go to my computer and select the drive that the camera is pluged into. Then highlight the picture files and right click. a pull dow will show you rhe other drives, select C drive and poof they are gone to c drive. If it asks you where on c drive select my pictures
Nov 29, 2008 | JVC Cybercam GR-DVL820 Mini DV Digital...
JVC GR-D31 Mini DV Digital transfer to computer burner??
Hi. Does your PC have an S-video socket? If so, I think it should be straight forward to connect the two.
Apr 07, 2008 | JVC GR-D31 Mini DV Digital Camcorder
JVC camera software GR-D70 for windows vista
Like most I have searched the web for drivers, preferably free ones. I emailed JVC Australia who responded with tis solution.
The camera has a connection called DV. The DV connection is used with a cable called Firewire.
Firewire is a driver less cable and will allow you to stream you video footage across from the camera to your PC.
USB is used for data transfer and need drivers, you would use this mainly to transfer still images or data files off a HDD camera.
If you use firewire and the DV connection you will stream the footage across to the PC and the PC will capture the footage as it is playing.
The firewire is about $15 and can be purchase from stores such as **** Smith, Bing Lee, Harvey Normans and Tandy. I would suggest that you take a photo of the connections on your PC as there are two types of DV connections. (4pin - 6pin)
Feb 12, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
Nov 02, 2006 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-D50 Mini DV Digital Camcorder Logo
103 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
