Question about Pinnacle Systems Studio AV/DV Version 9 Deluxe (202261744) Audio Input
After burning the DVD once, I can't do it again. The file used for the first burn doesn't work again
  • Tim Babcock
    Tim Babcock May 11, 2010
    Unless its a DVD-RW then you can re use it.
    The best thing to do is re render the files by inserting a new DVD and pressing create. You should select file and delete auxillary files from other projects as well in case you need more hard drive space for rendering.
  • 50 Answers
Hi Shedren
Try to see the link below: this will solve your problem
URL:http://pinnacle.custhelp.com/cgi-bin/pinnacle.cfg/php/enduser/std_adp.php?p_faqid=13874&p_created=1157054122&p_sid=OPINyMbj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzIyLDMyMiZwX3Byb2RzPTAmcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PWJ1cm5pbmcgZmFpbGVk&p_li=&p_topview=1
Regards,
Andrew
Pinnacle Support
Posted on Aug 20, 2008
  • 2,794 Answers
I'm changing this from a clarification to solution because this happens to me on occasion with the product.
Make sure your software is updated as well.
Posted on Jul 12, 2008
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
What size dvd 's are used to burn a movie from my Acer aspire 5517? I tried to burn a dvd and cd once and was unable.
The process is rather simple once you get the hang of it. Many people use various conversion software programs to convert their movie file to prepare them for a DVD. Although in the beginning it is complicated but after a couple of stabs at it. You will be burning movies.
The size normally would be 4.7 Gig standard DVD-R you can use RW if you plan to rewrite over the movie later. It will hold a single movie or approx: 4-5 depending on size if the files are not converted. You can convert the movie files using Winavi this is what I use. or you can try to find any free burning software program out there. Winavi for me was the simplest to process it is a approx: 3 step process.
You will be burning the Video from the file once converted. The audio is included during the burning process. All you need is one DVD-R place in the burner. Then open the conversion software and open the video file and convert and burn that is about it. For higher graphics quality it will take more of the disk space for less or normal it will take approx half the disk that way you can fit two movies on one disk basically. So the process is converting the movie to be prepared for the DVD to work on standard players.
Check out Winavi this is what I would suggest maybe someone else knows a free software conversion program you can use. John
May 10, 2012 | Acer Computers & Internet
I dont know how to download a movie so I can burn it
http://download.cnet.com/movie-torrent/3000-2196_4-10786348.html Movie Torrent is a basic peer-to-peer file-sharing client that lets users download a variety of different media types. Although the program works just fine, expect to seek additional instruction if you're not already familiar with torrents.
peer to peer file sharing is a free program which allows you to download someone elses movies that are online the link might drop out but will automatically search for anotherlink once its dropped out even if you shut your computer down after the link has been dropped when you start your computer again and open up the program will search for and connect to the link
once you have selected a movie the movie starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents then depending on your burning software you might have to burn it as an ISO image if you dont have the software to burn an iso image there are lots of free burning software programs on the internet http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
hope this helps you
Sep 05, 2011 | Compaq Computers & Internet
I dont know how to burn a movie to a blank dvd
open up your burning program depending on which burning program you have you can select either dvd or cd to burn an iso or make a cd/dvd movie once you have made your choice a browser should open navigate to your video file/s select it you might have to select an iso
((will depend on which burning program you have)) add to you should a graph oh how many mbs have been used once it loads select burn
if you dont have any burning software to burn dvd's
there are plenty of free burning software programs on the internet
hope this helps you
Aug 29, 2011 | HP DVD1040e DVD-RAM Burner
Im trying to figure out how to burn a dvd dont know how to do it
Before you decide to burn a DVD, it is important to know what kind of DVD you would like to burn. The type of DVD will usually determine the process you use to go about burning. The three most common types of DVDs to burn are Data DVD's, Multimedia Files to a DVD and making a copy and burning a commercial DVD. The burning process will be determined by the type of data you want to burn. You could do three possible actions:
  1. Burn Data to a DVD
  2. Burn Multimedia Files to a DVD
  3. Copy and Burn a Commercial DVD
Burning Data to a DVD Ordinary data such as documents, spreadsheets, database files and backup files require only general DVD burning programs. The data that you burn can be viewed on any type of computer with a DVD drive. Popular DVD burning software programs include Nero 9 and Super DVD Creator 9.8.8.
You will need to purchase or download any of the DVD burning software titles that are available on the market. For some computers that are purchased new, DVD burning software already comes installed and configured for your machine and DVD burner. You just need to open up your DVD burner software, choose to burn a data DVD and follow the instructions. You can usually burn a full length DVD (about 4.7 GB of data) in less than 20 minutes and even quicker with high speed DVD burners.
Burning Multimedia Files to a DVD
Multimedia files are usually larger files that include video either recorded from a TV set, camcorder or digital camera or downloaded from the internet. You may also want to convert an old VHS tape to a more user friendly DVD.
Copying and Burning a Commercial DVD
Many people use their DVD burner to burn copies of commercial DVDs. In most parts of the world, it is illegal to copy a commercial DVD and sell or distribute it. However, you may want to make a copy for archiving purposes.
There are many tools that can copy a commercial DVD. However, apart from the normal DVD burner and DVD burning software, you will also need special software that can decode or crack the digital rights management. It is also important to note that besides cracking the code and copying the data of the commercial DVD, you may need to shrink the file.
Most commercial DVDs are dual layer and have between 7 and 8.4 GB of data. These files must be compressed to fit on a normal 4.7 GB DVD. Once you have cracked the commercial DVD and compressed it, you can use ordinary DVD burning software to burn your DVD.
Jan 28, 2010 | Dell Inspiron E1505 Notebook
I just purchased a new DVD rewriter with Nero 7 Essentials, from Smartstart. I am trying to write an image file (.iso) to Memorex DVD+R disks. With the progress bar at 1% and before anything gets...
Were you able to write a single music or another file using Nero? Were you able to burn the image using the Active ISO burner? Did you try a new fresh blank DVD or are using the same DVD again? Try to free some more space from your C drive and then check again.
Oct 23, 2009 | Office Equipment & Supplies
NOT SRE WHAT THE PROBLEM IS NEED TO BURN DVD FROM ANOTHER DVD AND
Burning Data to a DVD Ordinary data such as documents, spreadsheets, database files and backup files require only general DVD burning programs. The data that you burn can be viewed on any type of computer with a DVD drive. Popular DVD burning software programs include Nero 9 and Super DVD Creator 9.8.8. You will need to purchase or download any of the DVD burning software titles that are available on the market. For some computers that are purchased new, DVD burning software already comes installed and configured for your machine and DVD burner. You just need to open up your DVD burner software, choose to burn a data DVD and follow the instructions. You can usually burn a full length DVD (about 4.7 GB of data) in less than 20 minutes and even quicker with high speed DVD burners. Burning Multimedia Files to a DVD Multimedia files are usually larger files that include video either recorded from a TV set, camcorder or digital camera or downloaded from the internet. You may also want to convert an old VHS tape to a more user friendly DVD. With today's DVD authoring tools, you can easily burn multimedia files and give them professional features such as adding a title or menu page or cataloguing many TV shows that you have already saved on your computer's hard drive. Some DVD burning software packages even allow you to add subtitles that you can create yourself. You can add DRM (digital rights management) with the help of your burning software, if you are creating commercial videos that you would want to make difficult to copy. Copying and Burning a Commercial DVD Many people use their DVD burner to burn copies of commercial DVDs. In most parts of the world, it is illegal to copy a commercial DVD and sell or distribute it. However, you may want to make a copy for archiving purposes. There are many tools that can copy a commercial DVD. However, apart from the normal DVD burner and DVD burning software, you will also need special software that can decode or crack the digital rights management. It is also important to note that besides cracking the code and copying the data of the commercial DVD, you may need to shrink the file. Most commercial DVDs are dual layer and have between 7 and 8.4 GB of data. These files must be compressed to fit on a normal 4.7 GB DVD. Once you have cracked the commercial DVD and compressed it, you can use ordinary DVD burning software to burn your DVD.
Dec 11, 2008 | Computers & Internet
Nero 7 burning used for pictures/video
There are many was to burn photo or dvd using nero.
The only thing you need to know is what format your dvd player accepts. If it accepts jpeg or kodack then you can burn staright to the cd.
If your dvd player hase Divx the tiy can burn any media to cd using Divx player. If not then you need to convert the file to dvd format.
Using Nero to make a dvd.
1. click on Nero and select DVD on the top middle and then click on the tab Photo & DVD
2. Then click on MAKE YOUR OWN DVD
this will open a new window here you need to select from the right hand side ADD VIDEO FILES.
3. Once loaded click next and let Nero recode the video format to dvd.
4. Insert a new dvd and burn it
This is the only way to recode a normal video file to dvd format.
Hope it works for you as its worked for me many times in the past.
Good Luck!!
Jul 07, 2008 | Ahead Software Computers & Internet
After burning my copied cd showing free space:0 ,i tried 5 cds ...same problem
it says free space 0 because it doesn't want you to add anymore files to it because it's most likely a burn once. it says used 700mb because again, it doesn't want you to add anymore files to it because, again, it's a burn once. do you get it?
Mar 10, 2008 | Computers & Internet
Everio GZ-MG130 everything!
Once I connect my camera to my PC and turn it on, none of the prompts work. It totally freezes- nothing- can't send videos to my computer or anything.
Jan 17, 2008 | JVC Everio GZ-MG130 Camcorder
Pinnacle Systems Studio AV/DV Version 9 Deluxe (202261744) Audio Input Logo
73 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
