Question about JVC GR-D31 Mini DV Digital Camcorder
Always "Check Tape's Erase Protection Tab"
Hi. Even when the cassette tab has been set to record, the display reads this? Thanks.
  • 1 more comment
  • Richard Kershaw Jul 12, 2008
    Hi. Tried turning the power off & different tapes. Same error meesage appears. Thanks
  • mobobmende Feb 22, 2009
    My JVC mini DV camera was dropped. There was no visible damage to the camera but it no longer records. Every other feature is working on the camera except a "check tapes erase protection tab" message appears when I try to record. I have tried a new tape and also have powered off and on with the tape in the camera. Any ideas?
  • guest Feb 12, 2013
    Mine is doing the same thing. I have tried several new/ used tapes, switched the protection tab both ways and tried putting tape over it, removed/reinstalled the battery, and cursed at the camera and threatened to throw it out onto the road, but nothing I've tried has made any difference.
  • 3 Answers
It doesn't work, i tried and it really starting to annoy me, and i really need the video camera, - also i only have one clean tape anyways. I really don't understand what the camera is doing. help!!!
Posted on Aug 01, 2008
Still the same message appears 8-(
Posted on Jul 16, 2008
  • 2,794 Answers
Turn the power off and back on again while the tape is in the player.
Do you have another tape to try to see it it's still doing it?
Posted on Jul 12, 2008
When I try to record the screen says 'check tapes erase protection tab'
Normally, tape cartridges have a protection tab on them that when removed prevents users from recording over. A piece of masking tape over the empty hole will allow you to record on the cassette.
Apr 07, 2015 | Video Cameras
VL-H86 PROTECT TAB IS ON AND ALL THERE IS ON THE TOP OF THE TAPE IS ERASE. HOW DO I GET IT OFF SO I CAN RECORD?
Let me reach back into the past here!
Well, protection tabs are on the cassettes. Video8 & Hi8 used a built in re-usable tab (unlike VHS, Beta etc which used a once only break-it-off tab, a method originating near 50 years ago with audio cassettes)
In reverse of the that method, when the tab is out (or slid over) recordings can be made on 8mm's including D8's and not when the tab shows.
they are located on the back edge of the cassette usually with indicator icons in the plastc of the case to help.
Sep 26, 2011 | Sharp Viewcam VL-AH151U Camcorder
I have a 720 Transcription System which I can't erase any data off. There is a padlock symbol on the LED display. How do I get rid of it?
There is a tiny switch in the mechanism that detects if the erase prevention tab is broken off the cassette. Try another tape to see if it is the tape, otherwise, that switch is probably broken. The tab is located to the right of the orange colored area on the picture. There is one one each side of the tape.
Jul 11, 2011 | Philips Desktop 710-T Desktop Cassette...
Vcr ejects tape when i try to record.
is the erase protection tab removed from the cassette?
if yes there is a square hole on the back of the tape visible when you insert it.
put a piece of sticky tape over this hole and make shure it does not come loose.
it should record fine now when you insert it again.
Aug 30, 2010 | Sony SLV-N51 VHS VCR
Dictaphone 2740
More than likely then the drive belt is broken or the motor is bad.
If you press the reset button the 88.8 flashing should go to 00.0.
If you are sure the tape is good, there is also a switch at the rear of the cassette compartment to detect if the record prevention tab is missing from the cassette itself. If the tab is in the cassette, the switch could be dirty or out of adjustment.
Aug 14, 2008 | Dictaphone 2740 Desktop Cassette...
The record mode does not function on the right side.It does play on both sides!
Place the speed on X1 mode to make sure it is off the B mode and it should record.
Jul 27, 2008 | Technics RS-TR373 Single Cassette Deck
Problem when Trying to record
If you are trying to record to a tape and the display shows "Protection", you must slide the protection tab at the top of the tape to the "Rec" position.
Jul 23, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Sharp Viewcam VL-AH151 Hi-8
Make sure the little red tab on top of the tape is set to record and not save. The camcorder will not let you record it its set to save
Jan 20, 2008 | Sharp Viewcam VL-AH151U Camcorder
Protection! Flashes on screen
This camera has a history of the flexible harness located on the cassette housing tearing when it rubs against the frame as the housing moves in and out. The harness tears and opens the circuit that detects the tapes record lockout tab, the camera is preventing you from recording on the tape in error. This repair requires replacemnent of the cassette housing, not for the faint of heart. I wish you luck. Joe Weibel customelectronics.org
Feb 04, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
JVC GR-D31 Mini DV Digital Camcorder Logo
427 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
