Question about Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer won't start
When I push the start button I can hear the timer switch getting power and making noises, but nothing else happens. I can push and hold start button down and feel the power getting to timer, but nothing happens after that. If belt was broken would I still feel heat out of dryer? I have the EXACT same issue. There is definately power to the outlet. I hear and feel the timer trying to work but the dryer does not turn on. It also seemed to make the clothes extra hot recently.
  • 2 more comments
  • vjt57 Jul 25, 2008
    I have the exact problem with my Kemore 110.63032100 as of today. Power is going to dryer, light goes on when open, timer dial makes noise when you press start button. Belt is good, barrel moves freely. Help!
  • johncerisano Nov 07, 2008
    My fuse keeps blowing, so I changed all the element fuse and the heating thermu and all the ones by the heating coils, the dryer ran well for a week and boom quit working, main fuse blew again, service cant fix it and my dryer is only 2 yrs old. The clothes are so hot you cant touch them. they smell like they are burning. this happens cause i put foil around the fuse and the dryer works but its to hot for the clothes
  • joeh915 Mar 29, 2009
    I have a kenmore elite 1 yr old,dryer,after a load is dry and put another load in,it does not start,but after 7-10 minutes it starts,can anyone help
  • brandenmitch
    brandenmitch Jul 28, 2012
    i cant find the number your talking about the model/stock number on the door is 180-00 and the serial number is mh2521960
    Problem Solver:
  • 11 Answers
DOOR SWITCH
Posted on Apr 20, 2009
  • brandenmitch
    how do i test the door switch? can i jump the circut?
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
When I push the start button on my Kenmore 700 series dryer nothing happens. You can hear the timer clicking as if it is getting power, but the dryer doesn't come on. Could this be a defective timer?
Check the door saftey switch and the start button for continuety.
My bet is the door switch.
Then look at the timer if both those are good.
Mar 19, 2010 | Dryers
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer
Do you hear the timer ticking?
Make sure there is 220 volts present at the terminal where the cord hooks to the dryer.
Inspect the wires for loose or burned.
Check continuity on the door switch.
Check continuity on the start switch.
Mar 11, 2009 | Kenmore Dryers
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
Mar 24, 2008 | Estate TEDX640JQ Electric Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
972 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
