Question about Kodak Digital Science 3520DP Path-Through Scanner
Kodak DS3500 scanner
I'm trying to scan documents on a Kodak DS3500 scanner that is giving me a can't communicate error.(check the power, cables and card)
Also I'm looking for information on testing the circuit boards or other hardware inside the scanner.
Thanks in advance for your assistant
Val
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this connected to a Vista computer?
    Problem Solver:
  • 14 Answers
Are you using a Kofax SCSI card or an normal SCSI controller like Adaptec?
By using a normal SCSI controller, is there an ASPI driver problem after a WIN XP update? After an update check the ASPI dlls in \sytem32. They should be version 4.71 or higher.
Check the SCSI connector pins and the terminator.
If available change the cable.
Scanner check:
Is the green lamp (Ready) on or is the red lamp (Error) on?
- green lamp on:
the internal self test is ok, but the internal SCSI interface may possibly faulty.
- red lamp on:
the internal selftest detect an error.
It's possible that the DC/DC power board, the CPU board or the power supply inside the scanner is defective.
After reassembling the front side camera you will see at the bottom a PCA board with some LEDs whitch indicate by red light the different voltages when power is on. You find the different voltages printed at the PCA close to the LEDs.
In case on or more LEDs don't shine the according DC/DC transformer on the PCA is defective.
Futher you see LEDs at the camera PCAs. They should be on too.
In case the CPU board has an defect you must have an special Kodak activation tool to unlock an new or used CPU board after exchange.
Posted on Jul 18, 2008
"cycle error" - scanner powers up ok but will not scan due to this error ID=055
Error 55: "Lamp I2C error reading from DAC". Operator log message: "Cycle power, if problem persists, call service.". This error is involves communication errors between the LED AY and the DAC. A couple things can be done to alleviate this issue but unfortunately, as a user, you can only perform the first step. The other steps require a Kodak Field Engineer to complete. First step, upgrade your Firmware. Firmware updates can be found at the following web page: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Production/i5200_Scanner/Support/Drivers_And_Downloads/i5000_Series_Scanner_Firmware/index.htm. If you still experience issues following the firmware upgrade, call Kodak Service & Support to schedule a field engineer to be dispatched to your site.
Mar 03, 2014 | Kodak i5200 Document Scanner
In canon ir 2016 there is no scanner movement & also the laser lamp is not glowing & the machine is indicating check document
In canon IR 2016j, if you get error " check document", its a communication error. so you check the flat cables in control board ( is a board in the scanning section)
* Change cable from scanning lamp
* change 2 cables from ip board.
Jun 12, 2012 | Office Equipment & Supplies
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
General error with epson tx111
mw tanya saya punya epson TX111 gimana cara mengatasi general error ketiga lampunya nyala bersama sama..mohon bantuannya...
Oct 10, 2010 | Epson Office Equipment & Supplies
Scanner not working
Hi Jkey !
As per the information you have provided, I understand that you are receiving an error "No scan option refer to the documentation" on the printer, when you try to print from the front panel of the printer (I mean from the printer's side).
However, plz provide me the proper error message so that I can assist you in the best possible way. If you are unable to scan from the printer's side, then try to scan from the computer and check if it is working or not. It should work when you try to scan from the computer, if not there may be a communication issue between the two devices.
To check the communication perform the below steps:
IF the printer is connected via USB cable, then perform below steps:
Useful scripts For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are able to scan fine using the above steps, please write back to me along with the exact error message.
With Regards
Mike.
Jun 27, 2009 | HP Photosmart 2575 All-In-One Printer,...
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Scanner
Try scanning from the Kodak AiO Home Center software. If that fails, you should get better feedback. Unfortunately, I have run into this when my ink is low. While it should not matter, is does. Check to see if you need to replace a cartridge.
Good Luck.
DigiChick.
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
Kodak Digital Science 3520DP Path-Through Scanner Logo
1,120 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
