Question about Pentax Optio S5i Digital Camera
Screws Missing The two screws which hold the casing together on the right hand side by the line in and out ports have fallen out. Everything is wobbling now. Is there ANY way and where any how I can find replacement screws? Thanks Tony twright05@gmail.com
  • Anonymous Sep 19, 2008
    I have the exact same problem. My screws just went missing! I haven't been able to find the specifications for a replacement.
  • Anonymous Mar 29, 2009
    Screws disappeared.
Same issue here although there has not yet been any effect on function. I do quite a bit of underwater photography and the images have remained very good without the screws.
The parts people at Pentax Imaging in Golden Co were very friendly in offering a free set of screws when I called.
http://www.pentax.com/subsidiary.html#n_america
Cheers
Posted on Feb 17, 2009
I had the same problem. I called Pentax. They sent a complete set (6 screws) free. -GG
Posted on Nov 16, 2008
I can't say i honestly know of any good fixes, but i have the exact same problem. manufacturer defect, perhaps?
Posted on Aug 15, 2008
Howq to take apart a compaq hp/ buisness desktop
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards You don't need to be a certified computer tech to upgrade your computer and remove malfunctioning components. All of the components inside your Compaq desktop computer are hidden behind the side access panel, and can be removed and replaced individually.
Turn off the computer's operating system and unplug any cables or devices connected to any of the Compaq's ports. Wait five minutes to ensure the internal components are cooled down. Set the computer case over on its side on a sturdy work surface. Touch either hand to the metal ports on the far-back side of the case to release any static electricity in your body. Remove both Phillips screws positioned at the back edge of the side access panel and set them in a container. Some Compaq models instead use a large plastic thumbscrew, which must be manually turned counter-clockwise to unlock the side panel. Pull the panel off the Compaq computer so the components inside the case are visible. Push in the plastic button on the edge of the front access panel. Pull the panel forward and to the right to remove it from the computer's case. Find the square metal box that houses the power supply at the upper-left corner of the case. Disconnect all of the cables connecting the power supply to the motherboard and the drives at the right side of the case. Remove the four screws holding the power supply in place and pull the entire unit out of the computer. Find the thin green memory modules positioned near the right edge of the motherboard. Depress the plastic locking latches connected to the top and bottom end of each module. Lift the modules off their motherboard ports and set them aside. Remove the two screws holding the plastic fan in place at the middle of the Compaq's motherboard. With some models you instead need to push down a metal clip. Disconnect the fan's cable and remove the fan. Lift off the metal heat sink positioned underneath the fan to reveal the square processor unit. Lift the plastic lever on the edge of the processor and pull the processor off the motherboard. Locate the line of horizontally positioned expansion cards near the bottom of the motherboard. Remove the screw holding each expansion card in place and remove the cards by pulling them directly upward. Locate the hard drive and optical drive in the metal bays at the far right end of the case. Remove the screws holding each drive in place. Push the drives forward and pull them out of the front end of the computer's case. Remove the screws positioned along the top and bottom edges of the motherboard. The exact number of screws varies between Compaq models, but will usually be eight or six. Slide the entire motherboard slightly towards the front of the computer case and pull the motherboard out of the case to finish disassembling the computer. Hope this helps.
Dec 20, 2012 | HP Computers & Internet
My gateway profile 4 all in one has a totally white screen with no display. Rebooted with normal
before thinking about replacing the video card
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
if you need to replace the video card it will be attached to the rear of the vga lead inside your computer usually in a pga slot
Remove your computer's cables.
Turn your computer around so the back faces you.
Remove the two screws on the computer holding the right side of your computer to the case.
On many models of gateway computers, you only need to remove the screws with your hand. Remove the right side of the case to expose the interior.
Unscrew the metal plate of your old graphics card holding it to your computer's case. Remove the card by sliding it out of the motherboard.
Slide your new graphics card into the slot from where you removed the old one. Screw the metal plate to your computer's case.
Reassemble your computer and connect its cables
hope this helps
Aug 02, 2012 | Gateway Profile 4 All In One (MPN...
How do I change the door from left hand to right hand opening
on the top right hand side of the refrigerator you should see little screw cover caps,, also on the door and on the bottom of the door. remove these caps -- now remove the screws that hold the hinges for the door and just switch everything over to the other side. everything is a mirror image of the other side --- where there is a screw that holds the hinge on one side -- there will be a screw hole on the other side that is covered by a finish cap,,, same thing with the hinge pin hole. tighten everything up and use the finish caps to plug up the now exposed holes and there you go -- right hand opening door.
if you have any troubles -- just write me back here and I will do my best to walk you through it.
c...
Feb 03, 2011 | Kenmore 72912 / 72914 / 72919 Bottom...
How do I disassemble the housing to get to replace the starter rope?
Hi.
Disassembly procedure depends on the make and model. Please provide model info for the unit.
Thanks.
Sep 04, 2010 | Garden
The USB port on the remote has fallen into the body of the remote. We removed the screws but still can't get it open??
The Ebay service is quite reasonable, but I give you fair warning. Many times when a USB port has become loose, it has done so due to some violent action. If this is the case, then it may not be a simple fix of re-soldering the port. If the solder pads have been ripped off the logic board, then this becomes a much bigger job and the Ebay service will not attempt a repair on the board itself. So, before you set yourself up for dissapointment, you should try to take a look inside to see if there is damage to the board. To open the remote remove the two screws. Then, near the bottom of the remote, on either side, stick your thumbnail between the two clamshell halves of the remote and wiggle it in until you open up a little space. Then, pointing your thumb down at about 45 degrees, slide your hand up the side of the remote. This will pop the small tabs that hold the remote together. Do the same on the other side and you will be able to separate the top and bottom clamshell halfs. Then, just pull out the red LED protective lens in the front. You should be able to recover the USB port and inspect the 5 small solder pads (thin silver-colored "fingers" on the logic board that the pins of the port were soldered to). If they all appear intact, you can attempt to repair yourself or contact the Ebay repairer as suggested. If any of the solder pads are missing, then the damage to the board is much more serious and, although it can be repaired, no one is going to do it for small change. You would probably be better off just buying a new logic board from an Ebay re-seller. They cost about $27.
Mar 22, 2010 | Logitech Harmony 890 LCD Remote Control
One of the paddles is loose and im not sure how to get the top poped up
unplug the dryer,open the door,take out the four screws,2 holding the door and the other 2 opposite the door screws,remove the door and pull the front off, you should be able to get at the loose screws down in the right hand corner,if you want to open the top take out the screws on top and remove the brackets that hold the side and the top together
Feb 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Hi I removed all the screws, and took apart my Toshiba Satellite M35X-S149 in order to resolder the power supply to the motherboard, however with everything out, the motherboard won't come out of the...
If you do not have a disassembly manual, here is one to go back and track your steps.....There may be other connectors you have not detached. Check carefully, screws aren't the only things holding the mobo in place. I think the M35 uses special nuts on the VGA port, these have to be removed for the motherboard to release....There appears to be one screw holding the system board to the lower case, with the board facing up, look in the middle and toward the top right edge of the board, there is a screw along the right edge. 2nd hole down, remove that screw and lift the right side of the board. Make sure all the wire and flat cable connections have been removed.
http://tim.id.au/laptops/toshiba/satellite%20m30-35.pdf
Nov 07, 2009 | Toshiba Satellite M35X-S149 PC Notebook
''start'' toast button no longer works on my kenmore toaster oven
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
Mar 21, 2009 | Kenmore KTES8 Toaster Oven with Convection...
Will not initalise DVD +RW
the spindle may need cleaning. if the spindle is dirty the disc will slip causing errors when burning discs.
to do this you will have to open the unit up and remove the drive from the machine.
undo the screws holding the casing together (7 In total) and remove the top of the unit
the drive is similar to a normal pc dvd drive and is held in a clamp
next undo the four screws holding the circuit board to the right of the drive and carefully move it to expose two of the four screws holding the clamp in place, the other two screws are already visible on the left hand side of the drive
now carefuly remove the two cables from the back of the drive and undo the four screws holding the clamp in place. you should now be able to lift the drive, still in its clamp, from the unit.
undo the four screws holding the drive in the clamp and slide the drive out
on the bottom of the drive there are four screws holding the casing together, remove these, and carefuly coax and tease the casing apart. dont use force, be gentle.
using a cotton bud and alcohol, carefuly clean the spindle, removing all dust and dirt. you may as well clean the lens and any other dirt from the unit whilst you have it open
put the machine back together by reversing these instructions
Sep 05, 2008 | LG DR-4912 DVD Recorder
Want to open my maxtor one touch, any idea of the best way, and what is that small openning at the back
It's a pain but you can do it if you are careful. Remove 2 screws on back panel, then gently remove back panel. Now work on side/front panel (one piece) GENTLY. They have little plastic clips that will pop out if you are careful. The you can remove 2 more screws on side that hold metal halves together. Top comes of clamshell style. Good luck !
Mar 30, 2008 | Maxtor OneTouch II external hard drive...
Pentax Optio S5i Digital Camera Logo
275 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
