Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer The lid switch is fine I had to replace it 2 years ago.I heard that they have had problems with the timers.If it is the motor how do I go about trouble shooting it? and thanks again for the help.
  • dostie_4 Jul 13, 2008
    Okay.Thank-you.Iwill check for aburnt wire and the wiring harness and then I might take ashot with a new timer.
    Novelist:
  • 177 Answers
Ok so your sure the lid switch is good, it fills with water and then it doesnt do anything, If you have tried all the cycles, at various points, it doesnt make any noises, I would assume it is the timer. However the motor or ? could still be bad.
I would take off the cabinet and look at the motor wiring harness and make sure some wire hasnt burnt off somewhere, and I would also look in the control panel for a burnt wire or worse.
then price out a timer and a motor and decide if you want to take a gamble and replace the timer, or do you decide to replace the washer since it has had problems before, I recommend one minor repair, after that I recommend replacement, cost vs time and warranty.
Posted on Jul 13, 2008
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
Just replace motor coupler a few days ago...now washer filled up, washed & got to rinse cycle then stopped. Turned dial back to wash cycle, won't work. Checked lid switch, not broken. Jumped outer...
since the coupler is new and lid switch was jumped i would be looking at the connections on the motor plug that you disconnected to replace coupler depending on your exact model there is the main plug the 2 wires on the capicator and a smaller plug. BUT FIRST recheck lid switch what must be jumped out is the connection leading up to control panel and NOT the part in the cabinet
to me a appliance tech w/30 years experience it sounds like a bad lid switch!
Aug 10, 2011 | Kenmore Washing Machines
Replaced lid switch a year ago, and the heavy duty cycle works fine. However, the permanent press/delicate and normal cycles do not work (tub just keeps filling/emptying water). My research indicates that...
I agree, it is most likely a timer problem. Possibly "rust" build-up.
See the Whirlpool / Kenmore Service manual for top load, direct drive washer for troubleshooting and diagnostics procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Nov 18, 2010 | Kenmore 24032\24036 Top Load Washer
The washer cycle stopped without warning, i thought the timer or the timer motor but it is not the timer works fine and so is the motor. but the timer motor runs til the washer motor starts than is the...
Confirm that the lid switch a common failure is working. A distinct click is usually heard when lid is closed. Temporarily by-pass to confirm and diagnose this type of problem. Confirm tab is in place on the lid.
Jun 28, 2017 | Jackson JPX-300L Dishwasher
Kenmore washer wont agitate
i would look at your lid switch this could be faulty
Feb 23, 2010 | Kenmore 22422 Top Load Washer
Kenmore washer 110.24642300 - the motor makes no sound. It will fill but that's it. No draining, spin or agitate. We replaced the lid switch about two months ago. Could it be a faulty lid switch?
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24642300
The first thing to try is to try a different cycle.
If the washer works, the problem points to a bad timer.
Second, it is possible that you had a defective lid switch. I'd try to by-pass the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Third, Try to set the timer to a spin cycle.
These washers use a reversing motor to run the drain and spin cycles.
If the lid switch is ok and the washer will drain and spin by starting in the spin cycle, the problem points to a timer.
Beyond that, the problem points to a motor connection area. See the troubleshooting guide and diagrams in the Whirlpool Service Manual.
Nov 17, 2009 | Kenmore Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
77 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
