Question about Waring WMK300 Professional Belgian Waffle Maker
Sticking waffles why & what to do, i cant use it
    Sergeant:
    Champion:
  • 417 Answers
Use cooking grease before you use it other wise it will stick
Posted on Jul 17, 2008
Need directios to use. waffle sticks to top and bottom
If it is a non stick waffle iron don't use a spray coating.
If it is a uncoated iron it is normal for them to stick for the first few uses. If you already have waffles stuck in the iron coat the stuck areas with cooking oil and reheat. Use a wooden or bamboo sewer to pick out the remains. Use cooking spray to coat the grids before cooking waffles. Try a different recipe. Some are more forgiving and don't stick as easily.
Jul 14, 2014 | Kitchen Appliances - Others
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
ProLine waffle maker sticking. Followed all direction from factory. No Pam used.
The plates on the waffle maker need to have some sort of cooking oil or butter to lubricate and prevent your waffle mix from sticking.
Spray some PAM on the plates once the correct temperature has been reached, or alternatively brush on a little melted butter or vegetable oil. Pour in your waffle mix and when cooked the waffle should lift straight off.
Jan 16, 2011 | KitchenAid Pro Line¿ Waffle Baker
How to clean the stove top waffler & keep waffles from sticking?
Best wasy to keep waffles from sticking is to spray the maker with a non stick food spray like "PAM". The other way is to increase the amount of oil in the batter, but that can affect the finished look.
Jan 10, 2011 | Nordic Ware 15040 Belgian Waffle Maker
Why does my waffles stick?
You have to lightly coat the waffle iron with vegetable oil, and then you won't have them sticking.
Otherwise, it's a mess!
Dec 12, 2010 | Toastmaster TMWB2BELW Waffle Maker
Why are my waffles sticking to my Philips KB5590 waffle maker?
WE HAD AN IDENTICAL PROBLEM. WE WASHED BOTH IRON SURFACES WELL AND THEN APPLIED A LIGHT COATING OF NON-STICK SPRAY. PROBLEM GONE - REPEAT AS NECESSARY AND HAPPY WAFFLING !!!
Jan 17, 2010 | Philips HD4482 Waffle Maker
Waffles sticking in a Salton wm-4.
Salton wm-4! one of the oldest waffle maker. The waffle is generally known to be difficult to clean. I would only advice you should always grease the plate before use. This helps make cleaning easy. You can also check our post on The Best Waffle Maker in 2017 The best waffle maker 2017 Easy buying guide Kitchenutilitypro
Sep 24, 2017 | Salton WM4 Waffle Maker
Waffles stick to both sides of iron
Lightly oil iron prior to heating it up. Use 2 Tablespons of oil in recipe.
Apr 06, 2009 | Kitchen Appliances - Others
Waffles stick in unit
If you add a 1/4 cup of melted butter or margarine to the waffle mix, they do not stick, mine don't stick at all. There is also a recipe using yeast, butter, etc, that makes excellent waffles, and they do not stick.
Aug 09, 2008 | Waring WMK300 Professional Belgian Waffle...
Waffle stickes
The question is! Was this waffle maker brought into the home new or used?
Jul 12, 2008 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
89 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
