Question about Kenmore 24 in. 17669 Free-standing Dishwasher
Kenmore free standing dishwasher 17799
My bottom dishes are not cleaning well at all. Food and residue is being left behind on a lot of the bottom items only. I've checked the sprayer arm and it is not clogged. Any other suggestions?
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
jbjaxiis
  • 95 Answers
SOURCE: kenmore dishwasher
Check the motor pump housing for an obstruction on the impellor. Impellors can go bad and not actually churn the water around the way they are supposed to.
Posted on Jul 06, 2008
  • 9 Answers
SOURCE: GE Profile Max Dishwasher
I,m not familiar with this make or model but all spray arms should be removable bottom normally pulls off top quarter turn and pull and the back water feeding tube can also be removed usually by clips.rinse through thoroughly and hook out food stuffs with needle from the eyelets.the cause is general build up but mainly pips seeds rice etc.solution is to rinse plates before going in machine also checking filter is firmly in place before wash cycle.remove and check filters regulary. hope this helps
Posted on May 18, 2009
  • 28 Answers
SOURCE: Asko1585 sprayer arm not working
Most likely the circulation pump. On this pump there is mounted a condensator. This will help the pump to get started. If this is broken, it wont circulate the water up to the sprayers.
Posted on Jul 27, 2009
  • 636 Answers
SOURCE: Residue inside dishwasher sprayer arms
What it is called is calcium deposits, your water is high in calcium. You may have to clean the part occasionally with CLR or something similar.
You should look into flushing your hot water tank occasionally as well, calcium deposit biuld up after awhile and your water tank has to work extra hard to heat your water, which cost you more money in the long run.
Hope this helps you .
Posted on Aug 15, 2009
Testimonial: "Thanks. I'll try it out. Do you know if Tang (drink concentrate) or citric acid work as well?"
Food residue and a thin film or coating is being left on dishes. Top and bottom shelf items are affected. Started happening 4 months ago after working perfectly fine for 4 years.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 15, 2011 | Kenmore 24 in. 17034 Built-in Dishwasher
Food residue left behind on my dishes on the top rack. The addition of a rinse agent doesn't seem to help. Suggestions?
heatman101
Oct 17, 2010 | GE Nautilus 24" Built-in Dishwasher
We just moved into a home with this dishwasher and the dishes just don't come out very clean. There is a "lot" of residue food left on the dishes. Could I be stacking it incorrectly or is there a specific...
Trky taking one cup of vinegar and put in the dishwasher and run it on wash cycle without anything in the washer and see if this helps you sounds like it is clogged up and not moving the water. Not an expert on this but this has worked for us.
Jul 06, 2010 | Fisher and Paykel 23 in. DD603H SS...
My dishwasher is leaving residue or soap scum on my dishes...
heatman101
0=0
May 02, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishes not clean - residue left on dishes and glasses dishwasher cleaner has been used. unit is 9-10 years old
Look on YouTube. Type in dishwasher repair, and you will find a number of tutorials that you will find helpful. It sounds like your soft food disposer needs to be cleaned out. Below the screen in the bottom, there are lots of nooks and crannies that can trap residue and recirculate it.
Best regards, --W/D--
Aug 12, 2009 | Maytag Jetclean® III MDB8601A Built-in...
Left over soap residue in glasses
you need to flush out the dishwasher, fill a cup with vinager and put it in the dishwasher standing up, then run the dishwasher thru a heavy duty cycle with no dishs. Then cut back on your soap, with new dishwashers and soaps you dont need much at all
Jul 08, 2009 | KitchenAid Food Grinder & Vegetable...
Residue and food particles left on dishes in upper rack.
Check the inlet screen at the bottom of the dishwasher that could impede the flow.
Otherwise the pump may be to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore HE2 Plus Front Load Washer
Dishwasher
Most dishwashers have a little filter basket in the bottom. Depending on the brand, you can slide out the bottom rack, and in the bottom underneath the sprayer (the propeller thing) there should be some sort of basket that can be removed and cleaned. You also may have some water quality issues, or some detergents will leave residue. Also, make sure most of the large food is removed before loading.
Nov 05, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Kenmore 24 in. 17669 Free-standing Dishwasher Logo
46 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
