Question about Jeep JX2LTV 5 in. Portable Television
Jeep jx2ltv ac power adapter or owners manual
I recently picked up this tv/radio/etc. used, but it didn't come with a manual and I think the ac adapter that was included was not meant for this device. I wondered if anyone could give me some info on the ac adapter. I can't find much on the web on this model, but other models have an ac adapter that looks like a tranformer type, and the one I have is a direct plug in. The only plug in point I can find on the radio is for 12vdc.
    Genius:
  • 1,027 Answers
You should be able to get the equivalent power supply at Radio Shack.
Posted on Jul 15, 2008
Do you know where i can find the cig adapter for my 1802 m radio?
I am guessing that you should be able to run it off AC power using a car inverter that works off the cigarette lighter socket. Something like this.
http://www.focalprice.com/ERZ92S/150W_DC_12V_to_AC_220V_Car_Power_Inverter_with_US_Converter_Silver.html?Source=EN_BFDproduct
Make sure you pick up the unit with the correct input battery and AC voltage rating for your radio. The operator manual is available from this site if you do not have one.
Welcome to Yaesu com
Aug 27, 2014 | Yaesu Radio Communications
I purchased the S350 for work. The company I work for just installed new fluorescent lights in the room that the radio plays. the problem is that while on the ac adapter. the radio pick up interference. ...
The speakers are to large for the Grundig to handle and should be removed. The fluorescent lights have a built in transformer that can cause problems when an AC adapter is used in a radio, but this is the case if one or more fixures have a flaw generating line noise which the radio would pick up. There are three suggestions you can try, relocate the radio in an attempt to correct the problem, purchase a noise filter from Radio Shack, or try and isolate the fixture that is the issue.
Jun 22, 2011 | Grundig S350 AM/FM/SW Radio
My Wii stopped working. Nothing lights up.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapterthat needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 04, 2009 | Nintendo Wii Console
My nintendo has no power going to it even tho the a/c adapter is hooked up
You'll need to unplug the AC adapter from the wall outlet and leave in unplugged for 5- or 10 minutes or so. Unplugging it from the Wii does no good.
This is a common problem with the Wii. As I said, I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked upto a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Not powering up
You need to reset the AC adapter (I explain how below). First, a little background on this issue. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Nov 17, 2009 | Nintendo Wii Console
BLOWES FUES TO RADIO/INTERIOR LIGHT/ETC
use a voltage meter to check the circuits for cotinuity if they are grounded out you may end up with even worse problems down the line. volt meter should read no load.
Nov 10, 2009 | 1998 Jeep Cherokee
My ac, power windows, the power locks, ALL Stopped working!!!
There is a power accessory relay under the hood or inside the fuse block/power distribution center that feeds these accessories. The relays wear out, rendering everything they feed inoperative. ChryCo often used the same part/numbered relay for several locations in the Power Distribution Center on numerous ChryCo-branded vehicles, including Jeeps.
Sep 12, 2009 | 2004 Jeep Grand Cherokee
Ac adapter
Hi I am an Indian too !
Of course you can use the 220v AC adapter, it will not harm your massager but may only underperform [slow speed, slow vibrations etc]
And be aware that the foreign products you receive, and have adapters rated at 120v are bound to get busted if you use them here in India, don't use them at first place.
Rather, buy an adapter rated for 220-240v for the same output voltage as that of 120v
Jul 12, 2008 | Televison & Video
Looking for a power supply
Sorry about the above post, but I wasn't signed in yet and this crazy GLITCH here put me down as a GUEST instead. The above post was mine, as I'm resending it again below.
Thx,
Frank
FRANK'S FIX IT SHOP
AC/DC power adapter + Power cord. 24VDC power adapter + power cord for Toshiba 20HLV15 20" Flat Panel LCD TV
Specification:
Input :100-240VAC (50-60Hz)
Output : 24VDC 4Amp (72W)
Part# ADP-2404-3PX
Approx cost: $50-60
Call Toshiba USA and give them that p/n for an exact cost quote plus shipping.
Best regards,
Frank
Apr 01, 2008 | Toshiba 20HLV15 TV
Bad adapter?
Dear Kerman,
Sounds like AC hum on your adapter; please find out the adpter voltage and polarity, on the adapter tips, maybe you user manual might have the information. Also the current rating of your adapter.
Try a replacement of the same rating and tip polarity.
That might solve the problem.
sidlahora
Jan 31, 2008 | Sangean ATS 818 AM/FM/SW Radio
Jeep JX2LTV 5 in. Portable Television Logo
322 people viewed this question
Top Jeep Televison & Video Experts
Are you a Jeep Televison and Video Expert? Answer questions, earn points and help others
