Question about Toshiba TDP-S8 Multimedia Projector
HOW TO RESET LAMP HOURS AND THE PROJECTOR WONT FIRE UP,STAND BYE LIGHT IS ON.sHOULD i LEAVE THE UNIT OFF FOR A WHILE THEN TRY AGAIN.I HAVE JUST REPLACED THE BULB AND I THINK WHEN IT KNOWS THERE IS A NEW BULB IT WILL TURN ON.THANKS-CHANGED LAMP
  • richardharle Jul 27, 2008
    just replaced bulb wont turn on, fan turns on for a minute. its a sanyo pro xtrax multiverse. thanks.richardharlenwebb@yahoo.com4
  • gasior78 Aug 14, 2008
    Same problem - don't know how to reset Toshiba's TDP-S8 lamp counter... heeelp! Thanx in advance!
From the booklet that comes with the replacement lamp:
1 While holding down the "MENU" and "ON/STANDBY" buttons simultaneously.
2. Insert the power cord
Not great English, but I tried this yesterday and it works.
Posted on Jul 17, 2008
  • 52 Answers
I have the same projector, and had the SAME problem.
After unplugging and taking on a trip it didn't work...it just lit up for 2 secs, and then shut off....
LEAVE it plugged in for as long as it takes for the light to stop blinking, and then it should start up on its own, or if you press the on/standby buton.
Be patient, hope this works for you too!
Posted on Sep 03, 2008
Thank you very much it worked..
I have a BenQ PB 6210. After switching it on, it first displays that the lamp has run 2001 hours and should be replaced. After this window disappears, it takes maybe 2 seconds and the projector shuts...
Hi cholthusen,
Please be informed that the average lifespan of a projector's lamp is around 2000 hours. The light bulb is almost certainly the problem. The best solution would be to change the bulb. The easiest way to do that is to change the lamp assembly (fresh bulb is in the new assembly). You may also try resetting the unit. Turn the unit off, then physically remove the power cord. wait for about 10-15 seconds then start it back again. If this did not work, please replace the lamp.
Hope it helps.
Thank you for using FixYa.
Jun 23, 2011 | BenQ PB6210-DLP PROJECTOR XGA Multimedia...
Will not coming on ,standby light is orange temp and lamp light not on
hi,
Just try to reset the lamp hour of your projector. For resetting the projector do the following.
While simultaneously holding down MENU/HELP, ENTER and Down arrow button on the projector, Press STANDBY/ON on the projector.
Remember one thing lamp hour reset is recommended only after the lamp replaced. Before going to buy a new lamp just reset the lamp hour and confirm that the projector doesn't have any other problem.
If these doesn't help then check the lamp of you projector chances for lamp became faulty.
ok
Mar 19, 2011 | Sharp XR-10SL DLP Projector
I have sony vpl-ex1 projctor and i have also changed the lamp of the projector but it still shows me the same message like change the lamp. Please advice! Thanks, Pravin Bhavsar
1.unplug power cord
2.plug back in and it should be in stand by mode.(red light on)
3.do not power on
4.on remote push RESET,LEFT ARROW,RIGHT ARROW AND ENTER(do it in less than 5 seconds)
5.after you have done this power on and go to menu and it should show lamp hours 0
6.if it didn't work just do it again, it took me a couple of tries.
Jan 04, 2011 | Sony VPL-EX1 Multimedia Projector
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
Optoma HD80 DLP - can't keep the projector lamp on.
remove lamp. put in freezer for 5 minutes. reinstall. when unit comes on go in menu and select lamp settings. reset to zero hours. it fixed mine. every month or two i have to do it again but its better then a new lamp plus check air filter
Nov 10, 2009 | Televison & Video
LP 240 stopped working. No lights, no fans, nothing.
Please describe the status of the LED indicator. No LED would indicate a failure of the power supply. I can help you with that.
Flashing red would indicate a fan/lamp problem. Some lamps fail prematurely before the lamp hours are up.
If it is the power supply, no lights at all, I can get you running again. These units have fragile power supplies that can burn out with the slightest power surge. A UPS goes a long way to save future headaches.
Jan 16, 2009 | InFocus LP 240 Multimedia Projector
Lamp hour reset
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Cheers
Dec 24, 2008 | Office Equipment & Supplies
LP130 projector - no light from lamp
there are several other issue that can arise with this unit
you may want to check out fixmyprojector.com
Jun 30, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Wil not turn on
Either your lamp is burned out or you had it unplugged for a while.
If you have had it unplugged for a while, plug it in, make sure the yellow power light is on, then wait for about an hour. Don't repeatly try to turn it on in the meantime. After about an hour or two plugged in,,,,, it should power up. Then reset your lamp timer through the menu.
Apr 02, 2008 | Toshiba TDP-T9U Multimedia Projector
Reset timer
FROM THE PROJECTOR
Press and hold the EXIT Button for 3 seconds to display the total used lamp time.
Then Press the MENU button on the projector during the lamp hour message.
The press the <-- or ---> button to reset lamp hours.
Press EXIT to leave.
Nov 15, 2007 | BenQ PB8220 DLP projector 2200 ANSI lumens...
Toshiba TDP-S8 Multimedia Projector Logo
2,440 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
