Question about Toshiba Satellite A105 Notebook
Fan Problem Fan doesn't work; computer overheats and shuts off. How much to have repaired??
  • MiamiMatt Jul 12, 2008
    Have isolated problem to fan off and computer shutting down after about 20 minutes in Internet Explorer only. What is problem??
    Problem Solver:
  • 7 Answers
dude, just one thing- have you tried checking if your computer has the latest version of "TOSHIBA POWER SAVER" and if it was running???
That's the ONLY utility that can control the screen brightness, CPU fan speed, and processor usage.
Posted on Jul 22, 2008
How do I troubleshoot my 1993 Saturn sl1 the fan doesn't work so the car overheats, beings I'm a female, tired of depending on a am , please help
If you know for a fact the cooling fan is why the engine overheats, you would test the relay and the signal from the computer.
The relay gets power from the battery circuit and the key switch, and a ground signal from the computer when the fan is needed.
The engine temp sensor tells the computer how hot the engine is, and when it reaches 220 degrees the computer grounds the relay providing power to the fan motor.
You would need a meter or a test light and the wiring diagram for the circuit to find the problem.
Oct 03, 2012 | 1993 Saturn SL
I have a HP Compaq DX2000MT computer. When I want to start up the pc, he gives 10 beeps and the following message : Chassis fan not functioning, check fan connections & call for service. Shutting...
Without the chassis fan the pc would overheat and fry so it's shut down. Do what the warning message says: open the case, clean the interior and check the wire connector of the fan. If the fan still doesn't turns then it has failed and it will have to be replaced - a new one costs$10 at every pc shop.
You will need the manuals for service and maintenance
Aug 07, 2011 | HP Compaq dx2000 Microtower PC Desktop
Oven lights and works fine till it reaches set temp then panel goes blank and oven shuts off
Check the cooling fan inside of your control panel. Most likely the computer board overheats and shuts itself down.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 25, 2011 | GE JGRS14 Gas Single Oven
Running hotter than normal looks like it started leaking bad under motor now
There is well-established procedure for trouble shouting the over heating.
Does the car overheat in driving mode?
Are you losing coolant?
No. Check water pump (including belt) and thermostat.
If yes make a radiator compression test. You might have a bad cylinder head gasket.
The car doesn’t overheat in driving mode, but overheat in idle.
Does the fan runs?
Check the fan assembly for a bad motor, loose fan blades, or bad connector.
Check the codes for a bad temperature sensor.
Check cooling fan relay and fuse.
If this isn’t enough to solve problem, then send the car at dealer for a “check and advice”.
Aug 24, 2010 | 2002 Chevrolet Malibu
Gigabyte GA-EP41-UD3L Intel G41 (Socket 775) the motherboard doesn´t run with an ati hd radeon 4650 gddr2 1gb constantly rebooting already tested with another ati hd radeon but gddr3 and runs can...
The card needs to be connected to a power source within the case, the main power supply, otherwise it will shut the computer down when it overheats. Make sure the fan on the card is moving.
Apr 12, 2010 | Intel Computers & Internet
Overheat and switches off automatically
check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
Jun 01, 2009 | HP Pavilion DV5-1000US Laptop
Computer keeps shutting off
the fans must work for the processor not to overheat..
thats why it crashes.. processors or certain hardwares need a certain temperature for it to run.
try repairing the fan it will help. and also clean dust on your board it insulates and increases heat inside causing your pc not to last long
Jun 04, 2008 | Acer Aspire T310 PC Desktop
My hp presario v2000 battery/fan does not work
The fan most likely needs to be replaced. When the computer overheats as a safety feature it shuts down. If you do not know how to replace the fan take it into a repair shop. The does not seem to be the problem.
Oct 25, 2007 | HP Compaq Presario V2000 Notebook
Toshiba Satellite A105 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
